Weights of major components?
#1 Weights of major components?
Does anyone happen to know the approximate weights of the XK engine, T5 gearbox, and IRS assembly? Getting ready to remove them and want to ensure my trolleys etc are up to the task.
John '62 S1 OTS (now sold)
T5 = 68lbs (standard Jaguar box 78lbs)
My guess (or reading it somewhere - Porter's book maybe?) on the other two is:
Engine = 600lbs (no ancillaries)
IRS = 350lbs (without wheels)
Certainly if you take the IRS out you need to put an equivalent weight in the boot to stop the car toppling forward.
S1 OTS OSB; S1 FHC ODB
David's weights are pretty much correct. The engine with gearbox is around 750 lbs.
Any trolley jack can easily handle the IRS assembly, but the unit tends to be nose-heavy and will roll forward as it's lowered from the car. The first thing to hit the pavement will be the pinion flange if this is allowed to happen. Jack stands can be placed under the longitudinal stiffeners just forward of the rear bulkhead.
One point worth noting is that it's important to not allow the IRS assembly to be suspended on the rubber mounts, especially if their condition is questionable. They were never designed to take tensile loads, so a jack should always be under the IRS when the car is raised. I also like to place a wood block on the jack pad when doing this.
If you've ever pulled the engine out of a Porsche 911, you'll find removing the Jaguar IRS to be a comparable experience. You can do it yourself, but the job will be much safer with a helper.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Thanks, guys.
Moe, I have indeed pulled 911 engines on quite a few occasions, always single-handed. The hardest part was always getting the body up high enough to clear the injection systems, and I got quite slick at removing the rear bumper assemblies as well to give extra clearance.
There is a slight overestimate of engine weight here. The engine and gearbox complete with ancillaries weighs about 680 lbs. If carburetters, manifolds, starter motor etc are removed then the lifting weight is about 610 lbs
