S2 FHC in the Paintshop
Topic author - Posts: 33
#1 S2 FHC in the Paintshop
Hi All,
My rather sorry S2 FHC is in the paintshop. A sad journey that has taken two long years of set backs. But hey, suddenly it is spring time in autum, The paintshop just posted through some progress photos. I am so chuffed I had to share some of them with people that would understand my joy (my friends and family certainly don't)! It is currently in high build filler primer. If you had seen the before pictures you would understand my happiness......
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#2 Re: S2 FHC in the Paintshop
What's your name...?....sorry to hear about what sounds like a bad history...what's the story...?
Looking forward to hearing and seeing more
Jonathan
Jonathan
#3 Re: S2 FHC in the Paintshop
Hi your Kris arnt you?......where have you been.....you started posting a while ago then stoped......great to see your progressing...exiting times... Steve
#4 Re: S2 FHC in the Paintshop
It is a long story which included a dodgy first paintshop that took 7 months to do nothing more than take a lot of cash and attack the rear of the car with an angle grinder. I then spent a year working on the car in a tiny garage repairing damage to the bodywork before finally taking it to the current paintshop (MechSpray) in May 2017. MechSpray are doing a great job. They are based in Rochester, Kent and have a very good Facebook page with photos of their work. It can be acessed through their web site http://www.mechspray.com.
Some details about the car, it is an early ex US S2 FHC 1R25275. Factory colour according to the heritage certificate is Damiler Silver Grey with Red interior. I will stick with factory colour exterior but am thinking to go with black interior. Red looks great but maybe too 'loud' to live with. Regards to all, Kris
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#5 Re: S2 FHC in the Paintshop
Here is a photo of the car in my garage around April 2017. I replaced the LH rear wing and toneau panel using Martin Robey supplied panels. Joints were lead loaded. You can see how cramped things were. Acess to the sides of the car was really tight. If I had more space to work in I might have tried to do some paint prep work before taking to MechSpray.
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#6 Re: S2 FHC in the Paintshop
Because of space limitations I had no chance to work on the bonnet in my garage. So it went off to IDL in Hastings for complete rebuild. Here are some pics.
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#7 Re: S2 FHC in the Paintshop
I found out the expensive way that new panels for the S2 bonnet are currently not available. IDL have done a great job working with the old panels. The centre panel and nose under panel were full of dents which all had to be removed. The RH wing was also beyond help. IDL managed to find a good used panel.
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#8 Re: S2 FHC in the Paintshop
Next step is for MechSpray to fit the bonnet to the body tub. Trial fits look pretty good but the bonnet still needs light filling in some areas to get it right. Apparently this is pretty usual.
Will post more pics as I get them....
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#9 Re: S2 FHC in the Paintshop
Hi Kris..looking good...please try to put your name and car model/year in as signature...makes it easier and more friendly for members to reply to you....Thanks Steve
#10 Re: S2 FHC in the Paintshop
Hi Steve, many thanks. Just found the edit profile tab and have put something meaningful in there. Kris
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#11 Re: S2 FHC in the Paintshop
I just spoke with the paintshop. I need to make a decision soon about wing mirrors. There is a hole in the drivers side door where a US aftermarket mirror was fitted at one time. I think this will need to be filled as I don't have the matching LH side mirror.
So I need to decide whether or not to put a pair of wing mirrors on or can I get away with no mirrors at all. I drove an MGC for years with no wing mirrors without any problems. Also I hear that the correct wing mirrors for the car are not much good anyway.
If I can get away without mirrors I would rather do so. Does anyone know what the DVLA view on wing mirrors would be. Will it pass an MOT without any fitted? If not, which are the correct mirrors and where best to source a pair.
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#12 Re: S2 FHC in the Paintshop
As wing mirrors were neither standard fitment nor a legal requirement at the time, your E-type will happily pass MOT without them.
For obvious reasons, many prefer these days to fit them. Personally my own car doesn't have them and so far I haven't found it a problem - riding a bike in traffic is excellent training, although I note you've driven a 'mirrorless' car before so will know what to expect!
1969 S2 FHC - 1R20258
#13 Re: S2 FHC in the Paintshop
Hi Kris
At least you now look to be in safer hands and positive progress is happening...
Looking forward to seeing more..!
Jonathan
Jonathan
#14 Re: S2 FHC in the Paintshop
Kris, as Simon says you won't need wing mirrors for the MOT, however these have recently been commented about and seem a good idea that will give you the benefit of seeing the boy racer but won't leave holes in the wings:
http://www.fossewayperformance.co.uk/e- ... or-mirror/
I certainly like having wing mirrors, but would fit the above if I hadn't already drilled the holes. Yes the wing mirrors are awkward to align to be of use!
#15 Re: S2 FHC in the Paintshop
Geoff, the mirrors from Fosseway look perfect and may well be worth a try. It is not clear whether they clip on to the door frame or it necessary to drill holes in the frames. This is still way better (in my opionion) than making holes in the wings. Since there is really no way back from that later if the mirrors don't perform well (not without a lot of expense).
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#16 Re: S2 FHC in the Paintshop
No drilling required.....they clamp on....i have very similar from SNG..Steve
#17 Re: S2 FHC in the Paintshop
Looking for a OTS 4.2 serie 1....! and now have found a fhc xk 140
#18 Re: S2 FHC in the Paintshop
Thanks Yves, they look perfect. In fact I have just ordered a pair! Regards, Kris
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#19 Re: S2 FHC in the Paintshop
Disaster with the bonnet!
Following the return of the bonnet from IDL in Hastings where it had been in for a complete rebuild, MechSpray have been working hard putting in more than 40 hrs on fitting/ filling and shaping it.
A short while after application of the filler primer it all started to lift......
A rep from IDL's paint supplier inspected the bonnet and the general thinking is that the base protection covering applied by IDL is defective. Investigations are still on-going but in the meantime IDL have stepped up to the plate and accepted the return of the bonnet so that they can carry out remedial work. Which at the moment looks like a complete strip of the bonnet back down to its components parts, re assembly, and then more shaping and filling to get it back to where it had been with MechSpray.
It means a good few weeks delay to the project but everyone is being very level headed and pramatic about it. These things happen and it is just as well for me that I am dealing with two longstanding and reputablle companies.
Will post further photos of the bonnet when it comes back from IDL.
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
#20 Re: S2 FHC in the Paintshop
Should point out that the white covering that lifted is a polyester filler and not a primer.
Kris
1968 S2 FHC
1978 VW T2B
1968 S2 FHC
1978 VW T2B
