Hello Dave,I was really highlighting that even these tiny items cannot be supplied with a better surface finish as I for one would be be prepared to pay a higher price to get a better quality item - especially on such small items - than settle for a poorer quality item even though I know they will do the job. It just hurts me to fit parts I personally don’t like the look of.
Its not the surface finish per se that is the issue, but surface finish in unison with the hardness of the surface; a soft bush, irrespective of how good the surface finish is, won't last long with needle rollers running on it. Even with a hard bush, because the arc of rotation of the bearing is relatively small, you will note that the brinelling is at the 4:0 o'clock to 8:0 o'clock area of the bush (provided that it's been prevented from rotating as it should). A soft bush would pound itself to death quick smart.
In an earlier Post, Steve wrote that he was able to source a bush of the correct ID/OD, but longer than required. If these bushes are of a suitable material, heat treated to provide a hard surface for the rollers to run on, they could be cut to length by either turning, or rough cut to length then finished using a surface grinder. Even if the surface hardness is in the 60's RC, some Carbide, and all CBN turning inserts will cut it.
