Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Topic author - Posts: 198
#41 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
The IRS will be back together this week with a new 3.07 diff, the various pieces are back from finishing. The seats and console have come back from refinishing.
Dana
Late S2 1970 OTS US LHD
#42 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Since the car is getting restored back to a European spec vs California, I'm looking for a set of European ribbed Valve / Cam covers without the notched step to go with the triple SU's. Can't seem to locate them here. Any ideas?
thx
thx
Dana
#43 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Dana
#44 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
They do come up from time to time on eBay UK, thats where I got mine.Lost Horizon wrote: ↑Tue Jan 23, 2018 1:44 amSince the car is getting restored back to a European spec vs California, I'm looking for a set of European ribbed Valve / Cam covers without the notched step to go with the triple SU's. Can't seem to locate them here. Any ideas?
thx
Here's is a restored set that available currently:
https://www.ebay.co.uk/itm/Jaguar-Ribbe ... SwTO9Z6xuB
Mike,
1970 S2 FHC 2R28165
1970 S2 FHC 2R28165
#45 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Hi Dane....why not post in the wanted section.....quite a few members have replaced their ribbed covers for smooth ones....so u might get lucky........i know postage to the Canada will be expensive....is there an option to somehow fill in the cutouts (tig) and have it machined.....just a thought... Steve
#46 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Thx Steve & Mike.
Dana
#47 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
If you are still thinking about ignition systems I see that Jag Lovers has an advert for an unused EDIS set up made by Ray L.
Widely thought of as being the best system around and no longer in production.
Tim
Tim
#48 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Thx Tim~
I went with the CSI system. It's interesting that the EDIS for sale over on Jag Lovers is from Saltspring. That's just a stones throw from here. It doesn't surprise me that much, as my Restorer has 3 XKE's undergoing full frame off restorations going on right now. A lot of European car lovers on Vancouver Island, and a lot of Classic Car expertise here. Plus we have a new Race Track nearby in Duncan that is world class, and well used.
Duncan Race Trak
Dana
#49 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Dana
#50 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Here's a short video of the final gap fitting before paint. We're getting there.
Final gap alignment before paint
Dana
#51 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Top Job, well done.
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#52 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
For sure. They are very good at what they do, and they do quite a few Jags, but also many other marks. The owner started out as a Master Mechanic for BMW.
Note the Series 1 in the background of this picture with mine. They typically have half a dozen Classics of various flavors in the line at any given time.
Dana
#53 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Body in White - pre fitting components, lining it all up. Since the Car will be dark blue, a lot of time is spent on perfect finishing. Looks good so far.
Dana
#54 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
The final body pre-fitting including bonnet, doors and chrome is done, painting is underway, bonnet has had the first clear coat sprayed, awaiting wet sanding. Should be done next week, then on to the drivetrain stuff.
Dana
#55 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
In the early part of this thread, I got some input from the members here on the 3.54 Diff as being a bit too short for my liking at highway speeds. I should bring some closure on the final decision on the discussion to make it taller, back to the European 3.07 preference/spec. Here's a couple of pics on how it got there with a DANA gearset with a 43-14 gear and pinion versus the original 46-13 factory, fyi.
and the final assembly:
Dana
#56 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Excellent. Check your discs dont foul on your calipers. Makes an annoying scraping noise at low speeds.
Easy to sort that one out before the IRS goes back in the car.
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#57 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Mike Owen, (the lead on the Mechanical side of things) inspires with such detail confidence on the multiple gotchas that can take the job sideways at every turn. I'm amazed at the level of detail and insight he has on British machines from that era. I will mention it to him, pretty sure he will patiently roll his eyes toward the ceiling, and say thanks. He's way past needing to use his ego on anything about "my" jag, because some of the stuff I've hand wringed over early on in this adventure seems somewhat silly now - and he could have easily shot me down, but simply said he'd take it all into consideration.politeperson wrote: ↑Tue Feb 27, 2018 8:33 pmExcellent. Check your discs dont foul on your calipers. Makes an annoying scraping noise at low speeds.
thx to you from me tho. Always happy to take input from folks on this site, as you can see from the thread so far..
Dana
#58 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Hi Dana..whilst your at it ask him about the handbrake upgrade, simple modification to improve it..photos here but plenty of info available.. Steve
#59 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Will do Steve.. thx
Dana
#60 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
On the Engine, I'm thinking that I'll get the crank, flywheel and damper dynamically balanced as the ring gear will be new and just to ensure it will be as smooth as it can be in zeroing the engine after weight balancing the new pistons, rings, bearings etc. In previously testing the engine on the stand after removal, there was a mild vibration around 2000 rpm. At the suggestion of someone here, I purchased an modern crankshaft damper to replace the original.
Living on Vancouver Island where there are excellent racing shops close by who do this sort of thing, for the few hundred dollars extra at this point seems to make sense. Make sense?
Dana
