Heater blade Series 3
#1 Heater blade Series 3
when i bought my Series 3 1972 the heater Fan/ box was missing. I have managed to find (from SNG) the heater box, motor and resistor but it looks like the blade is no more built.
Limora offers its and i have actualy ordered the part for 2 months but they said that they struggle to find a supplier. My order is still open but my level of hope is decreasing day on day.
My questions:
-Do you know where i could source it from?
-Is a blade from series 1 or 2 even if known as less efficient tahn the series can be fitted ? (Size and motor output diameter)
-Does a blade from other brand, model can be adapted to be fitted?
Many thanks in advance for your support.
Jérôme
My questions:
Jérôme
Jérôme
E type Series 3 - 2+2 1972
Peugeot 304 Cab 1971
Jérôme
#2 Re: Heater blade Series 3
Adrian Turner
S3 OTS & FHC
S1 FHC
XK140 FHC
S3 OTS & FHC
S1 FHC
XK140 FHC
#3 Re: Heater blade Series 3
There is a well documented conversion to upgrade heater fan output by using a Pontiac Fiero fan and motor although I'm not sure whether it is suitable for a series 3. This is what I have bought for my Series 1.
'78 Land Rover Series 3 109
#4 Re: Heater blade Series 3
Thanks. I saw this post but do not know either if it suits a series 3.Series1 Stu wrote: ↑Sat Feb 03, 2018 9:24 pmThere is a well documented conversion to upgrade heater fan output by using a Pontiac Fiero fan and motor although I'm not sure whether it is suitable for a series 3. This is what I have bought for my Series 1.
Regard
Jerôme
Jérôme
Jérôme
#5 Re: Heater blade Series 3
I bought all the Fiero parts to modify my Series 3 but I have not carried out the mod because the fan/squirrel cage is not deep enough. I have some ideas to modify further but I have not tried them yet because I am reluctant to modify the snail casing (the fan case) for the Fiero motor. I also heard that the fan from a Toyota Cami/Daihatsu Terios will fit, I can look for the details if needed. However, I did get a fan from SNG for the original motor, so I am surprised it is no longer available.
Series III FHC
Series III FHC
#6 Re: Heater blade Series 3
Simon,vee12eman wrote: ↑Tue Feb 06, 2018 11:29 amHi,
initially i have ordered the full kit from SNG (Cage, motor, Blade and resistor) but after a while they called me to inform that they could not get the balde anylonger. I fear that Limora will get back to me soon with the same answer.
Do you think that i should go for the Daihatsu/ Toyota one?
Thansk again.
Jérôme
Jérôme
Jérôme
#7 Re: Heater blade Series 3
Thanks.Whitact wrote: ↑Sat Feb 03, 2018 10:25 amHi Jérôme,
Clayton Classics might be worth a try:
http://claytonclassics.co.uk/
Cheers,
I just dropped them a mail.
I'll keep you posted.
Jérôme
Jérôme
Jérôme
#8 Re: Heater blade Series 3
Hi Jerome,
Here’s the link about the Terios unit:
https://forums.jag-lovers.com/t/e-type- ... e/100797/3
Might help if you sign up to the Jag Lovers Forum.
Series III FHC
Series III FHC
#9 Re: Heater blade Series 3
Good new, Limora just informed me that my blade in on its way. They fund it apparently.
I'll keep you posted as i remain cautious as as long as this will not be fitted and working i'll keep a doubt but it's a good sign.
Keep you posted.
Thanks to all of you for yoru help.
Jérôme
Keep you posted.
Jérôme
Jérôme
Jérôme
#10 Re: Heater blade Series 3
HI,
bad news !!!! What Limora sent me was an order cancelled few week ago (air vents).... this was not the balde i was looking for.
I guess i'll cancel the order and go for an alternative solution as suggested.
Thanks to all for your help.
Jérôme
Jérôme
Jérôme
Jérôme
#11 Re: Heater blade Series 3
Simon,vee12eman wrote: ↑Tue Feb 06, 2018 7:05 pmHi Jerome,
just ordered on Ebay this blower (MOT101 AC Heater Blower Motor for Daihatsu, Toyota Terios Nomada)
Jérôme
Jérôme
Jérôme
#12 Re: Heater blade Series 3
Dear all,
just to inform you that following the Simon's advice i have ordered a "cheap" units on ebay as suggestred and it works perfecty.
Many thanks for your help and support.
Special thanks to Simon
Jérôme
Jérôme
Jérôme
Jérôme
#13 Re: Heater blade Series 3
Hi Jérôme,
Glad to have helped. Did you end up with the Terios unit?
Series III FHC
Series III FHC
#14 Re: Heater blade Series 3
Simon,
i ordered this ref on ebay. 30 euros and i have the spare engine.
Almost a perfect fit - i have just slightly adjusted the central hole to fit to the motor axle.
I have no reference but it looks like the air flow is really good.
i'm getting close to the end of my restoration ;-)
thanks again;
Jérôme
Jérôme
Jérôme
#15 Re: Heater blade Series 3
Hi Jérôme,
Thanks for confirming the details. Your interior looks fantastic by the way. Good luck with the rest of the work.
Series III FHC
Series III FHC
