Original Late E Series II refresh as it unfolds (Aug 1970 Build)
1954Etype
#61 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by 1954Etype » Fri Mar 02, 2018 8:25 am
Always have the engine balanced. Pays dividends when you run it as the car feels really smooth.
Angus 67 FHC 1E33656
61 OTS 875047
Lost Horizon
#62 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Wed Mar 07, 2018 2:34 am
Big week. The body is complete, The car is moving back to the Mechanical and Electrical shop to start working on completing the various systems, engine and drivetrain assemblies. The paintwork is lovely, dark and deep -quite incredible, and the smartphone pictures hardly do it justice. Me happy so far. :bigrin:
Short walk around Video
Dana
Late S2 1970 OTS US LHD
Lost Horizon
#63 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Thu Mar 08, 2018 5:02 pm
Rebuild Day 1. Settling in, organizing and so on.
Positioning the shell
Working on the IRS. The diff is now 3.07 vs 3.54 with modern seals.
Today's video by Richard...
Note that the car will now have a heater, which it didn't have as a California car.
Dana
Lost Horizon
#64 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Fri Mar 09, 2018 8:30 pm
Grommets-R-Us
Dana
Lost Horizon
#65 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Sat Mar 10, 2018 10:09 am
Rebuild Day 2. Assembled IRS, work on the Front end suspension and steering rack.
Richard's Week End progress report
Dana
Lost Horizon
#66 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Fri Mar 16, 2018 1:07 am
The complete story of the IRS:
1. The original unit. Not in bad shape, but decided that it needed a 3.07 diff versus the 3.54. Since it had to come apart anyway, decided to zero the whole assembly.
2. Part of that was going to Koni Shocks, adjustable.
3. Today it's complete, ready to go back on the car with a 3.07 gearing, brembo discs, stainless brakeline etc
Dana
Lost Horizon
#67 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Fri Mar 16, 2018 5:03 pm
New Wiring Harness underway..
Dana
Lost Horizon
#68 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Sat Mar 17, 2018 4:45 pm
The gear box zeroed.. Bearings, shafts, pump, synchro rings and so on. Getting ready to put the cover back on.
Dana
Lost Horizon
#69 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Thu Mar 22, 2018 4:50 am
The engine has the "tappet guide stake down kit" which mechanically holds the tappet guides in place on the exhaust side.
Also, the original crankshaft still has STD Main bearings and is in great shape.
It is off to the balancer along with the flywheel and a new ring gear to be fitted, along with the connecting rods, new pins, pistons, rings, front crank damper, clutch assembly for matching weights and balancing.
A new ring gear was refitted by precise flywheel machining with an interference fit as there was a high torque starter installed at some point and damaged the original gear some. The builder has replaced the starter with a fully rebuilt original.
Dana
Lost Horizon
#70 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Mon Mar 26, 2018 3:07 pm
The build - Misc details from last week:
Everything is on schedule except for the new Triple SU kit being supplied/manufactured in the UK (Salisbury) by Burlen Ltd.
Further up this thread, we discussed the merits of SU's over Webers, so I went with the common consensus.
Initially talked to the Burlen sales department last year, they quoted Jan 30 2018 as the next batch completion date, so I signed up. They grabbed the money out of the gate, now it's been slipping a month at a time with the latest flexible foggy reasoning to (who knows?) the end of April. I was hoping to initially show the car in the the ABFM at Van Dusen Gardens (Vancouver) mid May, but as a result of the SU delays, not sure it will be sorted enough to do it and place appropriately. The showing includes a drive to Whistler on the sea to sky highway by the entrants. We'll see.
Dana
Lost Horizon
#71 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Thu Mar 29, 2018 3:40 am
A short video by Richard on part of the Engine balance and refurbish (bottom end)
Engine balance and bottom end rebuild
Some still pics on the Engine Rebuild (Bottom end part).
Dana
Lost Horizon
#72 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Fri Mar 30, 2018 2:32 pm
Engine is getting there. WIll likely go in with the trans next week. The Electronic Ignition distributor shown is CSI. More rebuild pics:
Dana
Lost Horizon
#73 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Fri Mar 30, 2018 9:09 pm
On the Body and frame side of things , the new electrical harness is nearly ready for the Drive Train and Engine to be reacquainted with the car, as well as the hoses, brake lines, pedal assemblies, accumulator, header tank and so on.
Dana
Lost Horizon
#74 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Tue Apr 03, 2018 4:48 pm
Someone asked me the other day how did they replace the ring gear, as it was originally machined directly on the flywheel.. Here is a pic of the fix. The machine shop milled the old teeth off to the appropriate interference diameter to suit the new ring gear, which was carefully heated just enough not to lose any temper when fit over the milled flywheel. Once done, it was part of the dynamic balance with the crankshaft, pistons, rods, pins, bearings, etc. mentioned up this thread. Here it is as it went back on the crank. The vice grips aren't holding it on, just there to make it easier to torque the bolts.... :mrgreen:
Dana
Lost Horizon
#75 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Thu Apr 05, 2018 1:09 am
Getting ready to reacquaint the restored drivetrain back in the car...
A short video of where we are
Some stills for those who like detail ~
Improved clutch throw-out bearing to replace the garden variety carbon version on the right:
Closeup of the CSI electronic Ignition. With the distributor cap on, it looks more or less original:
Original correct starter to replace the high torque version that was in the car previously:
Dana
Lost Horizon
#76 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Thu Apr 05, 2018 3:05 am
The engine and transmission are in. All good so far.
Dana
#77 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by politeperson » Thu Apr 05, 2018 8:29 am
Looks great.
Why dont you just run it in on Strombergs to run it in, then swap over to the SUs when they arrive. It would only take a couple of hours to swap them over.
James
Too many E types
XK120 SUs
Lost Horizon
#78 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Thu Apr 05, 2018 1:16 pm
James
I'm looking at several options. One is to borrow a set of SU's and manifold from another restoration that is scheduled later as being the most straightforward, since the manifold plumbing and air intake system to the carbs will be the same.
Under the faint hope clause, I spoke with Burlen on Tuesday this week and 'they' thought that the order should be done in the next week or so. Hope springs eternal.
Dana
Lost Horizon
#79 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Thu Apr 05, 2018 1:22 pm
A nice barn find by Richard Owen. He did a test fit, aligns great, drops right into the pins, and the windows are snug when rolled up. Onward.
Dana
Lost Horizon
#80 Re: Original Late E Series II refresh as it unfolds (Aug 1970 Build)
Post by Lost Horizon » Sun Apr 08, 2018 2:36 am
The engine bay is getting there. Hope the carbs show up soon ..
Dana
