Glue for the support rails seals
MLBS3V12
#1 Glue for the support rails seals
Post by MLBS3V12 » Sun Mar 11, 2018 9:11 am
Hi all,
I'm going to place back the seals support rails all arround the openings of the car, front doors and quarter lights.
When I've removed them there was a sort of glue Under them.
Who knows which glue has to be used to fit them back ?
Thank you for your feedback
Michel
Le chemin sera long!...
Jeremy
#2 Re: Glue for the support rails seals
Post by Jeremy » Sun Mar 11, 2018 12:35 pm
Don't think there should be any glue there. The seal retainers on mine were all held in place with pop rivets.
Jeremy
1967 S1 4.2 FHC
Ole-xke1974
#3 Re: Glue for the support rails seals
Post by Ole-xke1974 » Tue Mar 13, 2018 10:47 am
I believe what you have found is seam sealer which is also what I used on mine. I thin bead of seam sealer and then pop rivets to fasten the rails.
Cheers ..... Ole
#4 Re: Glue for the support rails seals
Post by mgcjag » Tue Mar 13, 2018 2:47 pm
It has been noted befor that if the retainers are not sealed water can get through then the blame is put on the rubber seals.....so yes seam sealer or the like should be used... Steve
