64 OTS Rear Bumper Overrider
64OTS
#1 64 OTS Rear Bumper Overrider
Post by 64OTS » Sat Mar 16, 2019 5:41 am
Just removed rear bumper (half the bolts snapped off!). I can't remove the bumper blade from the overrider as the bolt just spins, although I can't see any nut, captive or not. the parts book lists a 'grip nut' although I have no idea what this looks like, there does appear to be something like a washer on one side but this is free of the bolt. Any ideas before I resort to the angle grinder anyone?
Tim 1964 4.2 OTS
paulsco
#2 Re: 64 OTS Rear Bumper Overrider
Post by paulsco » Sat Mar 16, 2019 8:43 pm
Hi Tim,
I believe the 'grip nut' is like a nut enclosed by a clip that sits in a square hole in the overrider.
I bought some for my 65, but found that the overriders that I replaced them with had welded on nuts.
The only advantage I can see is that it might enable the nut to sit at a different angle to aid adjustment.
If I can find them and you need it, I might be able to post a picture.
You could try wedging it with a large screwdriver. Failing that you could grind the head off the bolt and possibly remove the remnants once the bumper is out of the way.
64OTS
#3 Re: 64 OTS Rear Bumper Overrider
Post by 64OTS » Mon Mar 18, 2019 4:06 am
Thanks for the reply. It looks like these nuts are the same as hold the sidepanel on my Triumph 650! Anyway, due to the exposed position they have rusted/ disntegrated such that I cannot get a grip on anything. I have put them to one side for later removal with the angle grinder. I may weld in a captive nut before I get the overriders rechromed. I also had to cut off the Amco bar. I quite like these so will be getting them rechromed too - now that I know how much they are to buy!!
Tim 1964 4.2 OTS
