satin or gloss black
adam
#1 satin or gloss black
Post by adam » Tue Jun 25, 2019 7:35 pm
Hi is the steering column adjuster gloss black or satin and the indicator stalk cowl satin or gloss black.On a 3.8.
Thank you Adam
#2 Re: satin or gloss black
Post by Heuer » Tue Jun 25, 2019 9:47 pm
Semi gloss, which is half way between gloss and satin. If you can't source semi-gloss go for Satin.
S1 OTS OSB; S1 FHC ODB
Turnip
#3 Re: satin or gloss black
Post by Turnip » Tue Jun 25, 2019 10:25 pm
You can get quite a nice shiney-but-not-glossy effect if you use satin paint and then rub it down with Solvol Autosol. I can't say if it's technically the correct look, but it seems OK on mine.
1965 Series 1 4.2 FHC
adam
#4 Re: satin or gloss black
Post by adam » Wed Jun 26, 2019 5:08 pm
Thanks for the info on original finish as I had seen gloss and satin finish on different cars.
Thank you Adam
