Hi All
I forgot to take a picture of the orientation of the sensor in the airbox. Would someone be kind enough to post a picture of it mounted in their airbox? I can't trace it on Google to see an open box.
The car is close to having an attempt at starting. Just need the airbox and vacuum hoses added, coolant and gearbox oil.
Air INtake Temperature Sensor - Mounted
#1 Air INtake Temperature Sensor - Mounted
Toby
2010 RRS Overfinch GTS
E30 M3 Turbo
E34 M5 Trackcar
V12 Roadster
E30 M3 Turbo
E34 M5 Trackcar
V12 Roadster
#2 Re: Air INtake Temperature Sensor - Mounted
Did you test if they still work?
Best Regards
Philip
Philip
#3 Re: Air INtake Temperature Sensor - Mounted
I believe they were when it was delivered by the garage 3 years ago.
So back to my original question regarding orientation. Which why do they go?
Toby
E30 M3 Turbo
E34 M5 Trackcar
V12 Roadster
E30 M3 Turbo
E34 M5 Trackcar
V12 Roadster
#4 Re: Air INtake Temperature Sensor - Mounted
Dear Toby,
If the bellows don't hold vacuum then it'll be academic, but it doesn't matter any way, as one side leads to blind dead end and one side goes to manifold vacuum.
Do whatever fits best.
