Cooling Fan Relay location
mach2andy
#1 Cooling Fan Relay location
Post by mach2andy » Wed Aug 14, 2019 4:38 pm
Some time ago I discovered a mystery bracket in one of my boxes of bits, and have just discovered that it is to mount the cooling fan relay to the picture frame. But exactly where? Can someone post a pic please? Ta.
Ash - You can probably see one of your wiring diagrams in this pic? Thanks again. It's been invaluable.
Andy Chalmers [in Hove]
1970 S2 FHC in pieces, but pieces flying more in formation now.
1965 SB Corvette Ragtop
Tom W
#2 Re: Cooling Fan Relay location
Post by Tom W » Wed Aug 14, 2019 5:21 pm
Mine is on the top of the picture frame, other side to the coil.
Tom
1970 S2 FHC
AshM
#3 Re: Cooling Fan Relay location
Post by AshM » Wed Aug 14, 2019 5:47 pm
Glad it's been helpful Andy - project looking great.
This photo should help (bit of non-original chrome on mine).
cheers
Ash
Series 2 FHC 1970
1R 20607
Tom W
#4 Re: Cooling Fan Relay location
Post by Tom W » Wed Aug 14, 2019 6:10 pm
The JCNA guise shows it where Ash has his, but with the bracket facing up. The bracket on mine mounted on the other side of the frame, but may well be wrong as some of the fan wiring and relay was missing when I got the car.
https://www.jcna.com/sites/default/file ... pe2(2).pdf page 9 in the PDF
Tom
1970 S2 FHC
AshM
#5 Re: Cooling Fan Relay location
Post by AshM » Wed Aug 14, 2019 6:57 pm
Thanks for that Tom. Very interesting. I will have to reposition mine.
I am missing the fan motor plastic covers too.
It never ends!!
Ash
Series 2 FHC 1970
1R 20607
mach2andy
#6 Re: Cooling Fan Relay location
Post by mach2andy » Wed Aug 14, 2019 7:58 pm
Ahh, sharing the inboard coil mounting bracket screw. That explains why the hole in the bracket is so large.
Thanks everyone.
grimes6
#7 Re: Cooling Fan Relay location
Post by grimes6 » Thu Aug 15, 2019 3:52 am
I have looked at the JCNA document and all the Series 2 's I have seen have had the relay mount as per Ash's pic. The parts book also shows the bracket as per Ash's pic.
Greg
Tom W
#8 Re: Cooling Fan Relay location
Post by Tom W » Thu Aug 15, 2019 5:02 am
Interesting. In the S2 originality sticky thread, it shows it facing down too, but that car doesn’t have the coil bracket as the coil is on the cylinder head. Maybe it’s wrong on the JCNA guide then, or maybe it changes when the coil moves to the front frame?
Tom
1970 S2 FHC
johnetype
#9 Re: Cooling Fan Relay location
Post by johnetype » Fri Aug 16, 2019 6:56 pm
There's no logic in having it pointing up and the original relays aren't waterproof so you wouldn't want one of those ending up pointing upwards or it would fill with water.
On cars with A/C the bracket is extended so another relay can sit below to turn on the fans when the A/C is turned on.
On my car which I have confidence but not certainty is as original in this area has it all pointing down like Ash's car.
1969 Series 2 FHC
mach2andy
#10 Re: Cooling Fan Relay location
Post by mach2andy » Sat Aug 17, 2019 8:41 am
I went for a more muted colour tone, and for the upward pointing option. The fan motor connections are marked 1 & 2 but theres no guidance on the wiring diagram as to where the supply & earth wires go. I'm assuming if I have this wrong, the fans will run backwards?
ATB
Andy
johnetype
#11 Re: Cooling Fan Relay location
Post by johnetype » Sat Aug 17, 2019 12:56 pm
Andy, I think you'll find that you'll have to fit the bracket the proper way, ie pointing downwards as when you come to fit the radiator and fans, the rear of the fan motor will foul the relay the way you've got it.
1969 Series 2 FHC
mach2andy
#12 Re: Cooling Fan Relay location
Post by mach2andy » Sun Aug 18, 2019 8:46 am
Hi John
You're absolutely right. It fouls the RH fan motor. Over it goes.
ATB
Andy
