Gear box oil.
Pbirty
#1 Gear box oil.
Post by Pbirty » Thu Sep 12, 2019 9:58 pm
Hello guys.
I'm looking for a bit of advice on changing my gearbox oil. I have looked into it a bit but getting varying answers on the best oil to put in there. It's a 1962 3.8 fhc with correct factory fit 4 speed moss box.
Thanks in advance Paul.
#2 Re: Gear box oil.
Post by rswaffie » Thu Sep 12, 2019 10:59 pm
Redline MTL.
Used it in my Healey 3000 moss box and now in my 63 FHC. Once warm, really helps the gear changes and makes it a nicer box to use.
Nearing completion of a comprehensive nut ‘n’ bolt restoration in my small, but utilitarian garage :wrench: :hammer: :fingerscrossed:
#3 Re: Gear box oil.
Post by Heuer » Fri Sep 13, 2019 11:16 am
:yeahthat:
S1 OTS OSB; S1 FHC ODB
lopena
#4 Re: Gear box oil.
Post by lopena » Fri Sep 13, 2019 1:06 pm
I recently switched to Redline MTL in my ‘64 OTS Moss gearbox and noticed a marked improvement in shifting.
Be forewarned, however, that if your gearbox has any leaks they are likely to get worse with MTL.
Alan
N.J.
Philk
#5 Re: Gear box oil.
Post by Philk » Fri Sep 13, 2019 2:25 pm
Alan
N.J.
I would reinforce this. For some strange reason, whilst Redline MTL has a higher viscosity (75/80) it is very, very thin when cold. As such, any seepage you would have from the seals with thicker gearbox oil will be exacerbated with MTL.
1964 S1 3.8 OTS
#6 Re: Gear box oil.
Post by Heuer » Fri Sep 13, 2019 2:45 pm
It also takes a few hundred miles before you notice any benefits to shifting. Most people say the same but no one can come up with an explanation as to why :shrug:
