Aluminium under dash panels change date
paulsco
#1 Aluminium under dash panels change date
Post by paulsco » Thu Oct 10, 2019 8:25 pm
Does anybody know what date(chassis number) that the under dash panels (Scuttle Top Castings, in parts manual speak) changed from aluminium to millboard?
Thanks,
Sarthe72
#2 Re: Aluminium under dash panels change date
Post by Sarthe72 » Fri Oct 11, 2019 10:21 am
About September 1963 from memory, but I haven't looked it up so may be a tad out.
Nick
#3 Re: Aluminium under dash panels change date
Post by Nick » Fri Oct 11, 2019 7:26 pm
Mine are aluminium either side of the steering column.
Nick
1E20498 1965 S1 FHC
paulsco
#4 Re: Aluminium under dash panels change date
Post by paulsco » Fri Oct 11, 2019 8:13 pm
Thank you both for your input,
I have noticed that there seems to be a wide spectrum of people who say that they have original aluminium panels, some on cars as late as 1966.
As far as I can establish, the part numbers remained the same throughout Series One production and maybe later.
I made some panels out of millboard, and they are quite flimsy and I didn’t like them.
My car did not come with any and I am now thinking of making some in aluminium and just wondered what might have been original to my November 65 car.
Moeregaard
#5 Re: Aluminium under dash panels change date
Post by Moeregaard » Sat Oct 12, 2019 2:45 pm
My very early 4.2 FHC, built 9/64, had the alloy under-dash panels.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
andrewh
#6 Re: Aluminium under dash panels change date
Post by andrewh » Sat Oct 12, 2019 8:43 pm
1966 4.2 Roadster has aluminium.
1962 3.8 Series One FHC
Sarthe72
#7 Re: Aluminium under dash panels change date
Post by Sarthe72 » Sun Oct 13, 2019 8:30 am
This information is taken from page 78 of the latest Thomas Haddock reference book, and as I thought the change from alloy panels to leather(vinyl came later) took place in September 1963. Prior to that there were two styles of alloy dash, one dot pattern for the early cars and the other like a series of plus signs. No car after September 1963 should have an alloy dash panel, and if it does it was probably changed for appearance by a previous owner.
andrewh
#8 Re: Aluminium under dash panels change date
Post by andrewh » Sun Oct 13, 2019 9:06 am
They are not referring to the alloy facia but the under panels. The ones with the trip reset and clock adjustment fixed through Tony
#9 Re: Aluminium under dash panels change date
Post by PeterCrespin » Sun Oct 13, 2019 9:11 am
My S3 and al my S1.(/S2s had millboard panels. Of the S1s, some bad Rexine-covered alloy and several had lost their panels.
My April 66 2+2 came with alloy each side of the column but I can’t prove they were original. The 2+2 under-dash area was substantially different from SWB cars and they used a lot of millboard for the extra glove trays under each side. They were first to use heater footwell diffusers controlled by dash knobs and the first to have a locking dash cubby lid, all of which one could imagine coinciding with a change to pre-finished stamped millboard panels at significant saving of time and money?
Philk
#10 Re: Aluminium under dash panels change date
Post by Philk » Sun Oct 13, 2019 4:34 pm
My June '64 S1 3.8 OTS has the aluminium under-dash panels with Vinyl over them.
1964 S1 3.8 OTS
