TRIPLEX logos research - a bit of help needed
ysmalkie
Poland
#1 TRIPLEX logos research - a bit of help needed
Post by ysmalkie » Wed Jan 15, 2020 10:20 am
I have been researching the TRIPLEX logos on Jaguars for quite some time.
Here goes a fairly complete sheet with logos for different glass of the e-type.
As you can see, I am missing some of the logos, for example I do not have any ’64 glass logos for rear or side screens.
The side glass logos have varies quite a bit:
- The font evolved, especially on the TRIPLEX
- The AS2 seemed to be placed on the bottom for ’63 glass, but only for the door windows
- The door windows were printed in reverse (but always identical left & right)
- From ’65 (’64?) onward additional markings were introduced
- The size of the logos have varied
- The mysterious dot in the middle of XXX popped up and went away – I have no idea what it meant.
- The heart was of 2 or 3 designs varying by the shape of the S and the top.
- The headlamp glass had extra dots between TRIPLEX and TOUGHENED.
- The S (sheet) glass was mostly used for door windows while P (Plate) glass was mostly used for other side glass.
- ’67 heated boot lid glass was made in AS1 quality!..
Other symbols explained:
L – Laminated
T – Toughened, heat treated
P – Plate Glass
S – Sheet Glass
T – Toughened Glass
V – for vehicle use??
F – Float Glass, used since ’63 when float glass begun to be available
WF – Front windscreen quality – used since 65
AS1 or AS2, where AS stands for American Standard. AS1 means glass is with at least 70% transmission and can be used anywhere on a vehicle (by default used on the windshield), AS2 is used for side glass.
M3 or M6 – Manufacturer codes, describing different models of glass – used since ‘65
French Homologation Designation, used since ’54. It consists of “AGRÉÉ” and the standard designation: TP.GS.6
- AGRÉÉ meaning certified, authorized.
TP.GS. meaning “Transport Publique, Gestion de Securite” – the homologation body) and 6 is the homologation number. In ’66 the French homologation designation changed from the two line format to single line and now read: AG TPGS6.
D - German approval, introduced in ’67. It was a sine wave followed by letter D and a number. D90 was used on ‘60s Triplex glass.
The windscreen glass also varied, however to a lesser extent. There were fewer versions of it.
I need photos of the logos that are missing please - your help will be most appreciated.
Also, if your glass logo is different than specified by me for a particular year, please let me know.
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Philk
#2 Re: TRIPLEX logos research - a bit of help needed
Post by Philk » Sat Jan 18, 2020 8:36 am
Hi - I can help with the 1964 S1 3.8 Door Window. Photo below.
1964 S1 3.8 OTS
ysmalkie
Poland
#3 Re: TRIPLEX logos research - a bit of help needed
Post by ysmalkie » Sun Jan 19, 2020 8:21 pm
Many thanks Phil. Much appreciated.
What month is your car from?
Would you have any other side/rear '64 glass?
Tadek
Tadek
Jaguar XK120 OTS
Philk
#4 Re: TRIPLEX logos research - a bit of help needed
Post by Philk » Sun Jan 19, 2020 11:04 pm
Tadek
Hi - it's a June '64 roadster so no rear glass. From the car's history file, the other side glass was replaced in May 1988 so we do not have the original logo.
1964 S1 3.8 OTS
ysmalkie
Poland
#5 Re: TRIPLEX logos research - a bit of help needed
Post by ysmalkie » Mon Jan 20, 2020 9:51 pm
Thanks Phil!
Tadek
Jaguar XK120 OTS
