3.8 seat frame colour
ollieoscarsid
#1 3.8 seat frame colour
Post by ollieoscarsid » Sat Feb 15, 2020 6:42 am
Can anyone help with a colour for the seat frames on a 3.8? I can’t find anything in the knowledge base. Mine were a kind of dove grey. Thanks. Chris.
1963 S1 opalescent silver blue
#2 Re: 3.8 seat frame colour
Post by abowie » Sat Feb 15, 2020 7:23 am
Primer colour. Doesn't matter; you can't see them.
noli383
#3 Re: 3.8 seat frame colour
Post by noli383 » Sat Feb 15, 2020 9:00 am
Chris,
Yep, BS381C-694 Dove Grey is the colour I used - perfect match. Incidentally I believe the factory only painted the lower area which is visible under the seat cushion & underside of the seat if removed. The “vertical” backrest behind the moquette etc. was left raw steel .... well, that’s what I found when I removed the trim on mine. I suspect this is factory correct as I also found the body number in crayon on the backside of the leather panels. Of course, I chose to paint the whole shell prior to re-trimming.
62 3.8 DHC
andrewh
#4 Re: 3.8 seat frame colour
Post by andrewh » Sat Feb 15, 2020 9:54 am
Is this Dove Grey the same colour as the soft top frames can anyone confirm?
1962 3.8 Series One FHC
#5 Re: 3.8 seat frame colour
Post by Heuer » Sat Feb 15, 2020 3:28 pm
Yes, a British Standard colour.
S1 OTS OSB; S1 FHC ODB
andrewh
#6 Re: 3.8 seat frame colour
Post by andrewh » Sat Feb 15, 2020 3:30 pm
thanks David. I thought they looked the same colour.
ollieoscarsid
#7 Re: 3.8 seat frame colour
Post by ollieoscarsid » Sat Feb 15, 2020 6:37 pm
Thank you gents, colour looks super. To the paint shop in the morning. 😊
MarkRado
Austria
#8 Re: 3.8 seat frame colour
Post by MarkRado » Mon Feb 17, 2020 10:30 am
Noli, could you post some photos you have taken during dismantling? Originality is always interesting, even if one does not always follow this path.
1963 OTS 880436
#9 Re: 3.8 seat frame colour
Post by rswaffie » Mon Feb 17, 2020 3:49 pm
MarkRado
Austria
#10 Re: 3.8 seat frame colour
Post by MarkRado » Tue Feb 18, 2020 5:09 am
Thank you Richard, perfect documentation!
1963 OTS 880436
#11 Re: 3.8 seat frame colour
Post by rswaffie » Tue Feb 18, 2020 7:15 am
No problem. There’s quite a few more if you need them - I photographed the entire strip down as I went along.
MarkRado
Austria
#12 Re: 3.8 seat frame colour
Post by MarkRado » Wed Feb 19, 2020 5:40 am
Yes please! Thank you
1963 OTS 880436
