Sweating Brake Reservoir Hose
SESH
#1 Sweating Brake Reservoir Hose
Post by SESH » Mon Mar 02, 2020 3:32 pm
The brake reservoir hose on my series 3 is sweating.
So I will replace it.
Can anyone confirm best hose and dimensions.
I tried to measure the existing one on the car and the length looks to be about 30cm and the diameter of the outside is around 1.7 cm. But I think the internal dimension is normally the measurement to use.
Is Cohline 2337 suitable?
Mike
1973 Series 3 OTS Signal Red
#2 Re: Sweating Brake Reservoir Hose
Post by christopher storey » Mon Mar 02, 2020 3:48 pm
Mike : be warned that this is probably not sweating, but that the line has become porous and is weeping brake fluid, which can be highly damaging to paint . Wash everything down with water at very frequent intervals until the hose has been replaced
#3 Re: Sweating Brake Reservoir Hose
Post by Heuer » Mon Mar 02, 2020 5:37 pm
Yes, we know about it - see here: viewtopic.php?p=15015#p15015
You need Cohline hose.
S1 OTS OSB; S1 FHC ODB
SESH
#4 Re: Sweating Brake Reservoir Hose
Post by SESH » Mon Mar 02, 2020 6:19 pm
Thanks David and Christopher.
I am intending to get some Cohline 2337 from Merlin Motorsport.
Is this the correct pipe?
https://www.merlinmotorsport.co.uk/p/7m ... =2337-0613
Looks quite reasonable at £1.32 per 100 mm + VAT.
My current sweating pipe has a yellow line along its length.
Thanks again.
Mike
#5 Re: Sweating Brake Reservoir Hose
Post by rswaffie » Mon Mar 02, 2020 7:08 pm
I’ve just fitted that cohline hose from Merlinsport, as the hose I got originally from one of the etype parts suppliers sweated/leaked due to porosity (is there a difference?) after 3 months! That was after one of the new fluid reservoirs split at the spigot so I seem to have spent a lot of time mopping up fluid. :cussing:
SESH
#6 Re: Sweating Brake Reservoir Hose
Post by SESH » Mon Mar 02, 2020 11:44 pm
Thanks. Will get some ordered.
Mike
