When I removed the cap, it was coated on the inside with a baked on substance and the rotor was disintegrating. The rotor plastic had softened and coated my hands as I tried to remove it. It was locked onto the shaft, presumably due to the degradation of the plastic. I clamped the outside of the rotor to remove it. The entire rotor was soft, both the top and bottom. The cap was coated with with Foreign matter, and was completely dry. No signs of oil. The plastic cover was clean and showed no signs of contamination. The reluctor and the base of the distributor was absolutely clean and free from oil or other visible contamination. The cap gasket was intact and the imprint looked exactly like it should. Indentations where the cap was sealing against the distributor base. No appearance of a way for the foreign matter to be introduced inside the cap.
I emailed SNG and unfortunately with the covid issue, no technical support was available. I ordered a new cap and rotor and after installation, the backfire issue was resolved.
I will send photos from my phone after I post this, Has anyone else seen this issue with US based replacement distributors.
