The E-Type World Map
#1 The E-Type World Map
Post by Heuer » Sun Oct 03, 2010 1:12 pm
Want to know if there are any E-Type owners near you? You can use this map to see who is close by and add your own location: https://www.zeemaps.com/map?group=184509
No need to subscribe, give out your email, join anything and you don't even need to be a member of the Forum or The E-Type Club!
Basically it is an E-Type owners map you can annotate with your location, user name, photo and car type. Obviously it would be sensible not to put in your exact location but a town name, postcode or even a nearby field would work. :shock:
At the bottom you will see a list of coloured push-pins which I have added, one for each model type. If you fancy entering into the spirit simply click on the third menu item 'Additions' and then 'Add marker - simple'. Enter your details, choose the push-pin from the drop down list to match your model and then click submit. Map is world wide so use the zoom and pan controls to move about.
Please bookmark or write down the unique URL you are given as it is the only way you will be able to edit your entry:
Clicking on a push-pin should open a box with the owner name, details and maybe a photo. Click on an existing pin for an example. Don't worry if you make a mistake you can delete the entry or change it at any time.
S1 OTS OSB; S1 FHC ODB
#2 Re: The E-Type World Map
Post by Heuer » Sat Jun 09, 2018 12:31 pm
An update on the E-Type map feature.
As of 1 April Zeemaps introduced a $20/month subscription for this service. Julian Barratt has kindly agreed to sponsor the World Map of E-Types and it will now include the SNGB branding. All the existing map pins are there so please feel free to add your E-Type to the map (instructions in the above post).
It is a useful feature as it gives owners a sense of how many others are around them.
Locked Previous topicNext topic
