Series 2 aesthetics
Herzeg
#201 Re: Series 2 aesthetics
Post by Herzeg » Tue Feb 12, 2019 9:53 am
Hi Marek
I have your original led reversing lights. Are you able to swap out those for the new ones, or do you need to replace the whole unit?
MarekH
#202 Re: Series 2 aesthetics
Post by MarekH » Tue Feb 12, 2019 1:26 pm
The new boards are a press fit into the clear Lotus bit of the rear lenses.
Since yours date from May 2016, I'm guessing you'd have to use a scalpel (or Dremel) to cut a hole in the back of the lenses to be able to remove the old LED board. Alternatively, delicately inserting a scalpel between the clear housing and the main body may pry the clear part free.
Later units are a simple swap over as they are unsealed.
mark10337
Switzerland
#203 Re: Series 2 aesthetics
Post by mark10337 » Mon Apr 08, 2019 1:11 pm
Are the LEDs "E" marked, like bulbs have to be? I have had a ticking off from the authorities for the reversing lights on the MOT test :sad:
-Mark
MarekH
#204 Re: Series 2 aesthetics
Post by MarekH » Tue Apr 09, 2019 10:33 am
The MGB square lights used by Jaguar will have had markings on them. The clear inserts that make a standard s2 or s3 rear light into a "Lotus" light never had any markings on them. All I have done is change the festoon bulb for a brighter array of LEDs, neither of which ever had markings.
The markings on the s2 or s3 main orange/red rear housings are exactly as before.
