The 'E' Type Forum - celebrating 55 years of the ultimate motoring icon Forum Index The 'E' Type Forum - celebrating 55 years of the ultimate motoring icon
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
S2 Brake servo wanted
Goto page 1, 2  Next
Post new topic   Reply to topic    The 'E' Type Forum - celebrating 55 years of the ultimate motoring icon Forum Index -> Series 1
View previous topic :: View next topic
Author Message
neil4444
PostPosted: Fri Mar 06, 2009 10:52 pm    Post subject: S2 Brake servo wanted Reply with quote
Hi, I am just in the process of ordering a new bodyshell sub-assembly for my 3.8 S1 OTS and have been advised to consider installing the appropriate pedal box to accept the improved S2 brake servo (rather than the current S1 bellows). Question is, where can I find an S2 brake servo as all the companies I have found only provide them on an exchange basis. I would much appreciate any advice.
Neil4444
Back to top
View user's profile Send private message
MarkE
PostPosted: Sat Mar 07, 2009 8:41 am    Post subject: Reply with quote
You can try RM & J Smith in Crew (01270 820885) (rmj@rmjsmith.fsnet.co.uk). They supplied me with quite a few goodies for my S1. However, if you have to change the pedal box as well, that will be a bit more tricky to source.
It may be worth getting other opinions regarding getting rid of the bellows servo, and finding out if they can now be rebuilt. Classicar Automotive in Cheshire provide a great service for overhauling servos, callipers etc., and they would at least tell you if your servo can be overhauled. You can get hold of them on 01625 860 910 or sales classicbrakes.co.uk.
Iíve certainly seen plenty of S1s still with their bellows servo, and as a unique feature of the early cars, itís nice to see and must enhance their value. If all cars are updated to the optimum spec, they do lose something of their original appealÖto me at least!
Back to top
View user's profile Send private message Visit poster's website
neil4444
PostPosted: Sat Mar 07, 2009 9:29 am    Post subject: Reply with quote
Mark,
Thanks for info. I must admit it is somewhat of a dilemma as to whether to replace the bellows with the later servo type. I'm all for originality but also want to make sure the car is a safe and enjoyable as possible. I suppose I'm being led by the many opinions I've read concerning the brake fade on the 3.8 S1's. I am entering this restoration project not having driven an E-Type before so its difficult for me to decide which way to go.
Appreciate your advice !
Neil4444
Back to top
PostPosted: Sat Mar 07, 2009 9:53 am    Post subject: Reply with quote
neil4444 wrote:
Mark,
Neil4444
Mark,
there is another way. On the early S1 4.2 cars, they fitted an intermediary pedal box which fitted directly onto the 3.8 bulkhead. The vacuum pipes were attached to the outside of the bulkhead (later the bulkhead was modified to take the pipes inside). The downside is that these boxes are expensive (as they are quite rare) and I have seen them going for £700 at Stoneleigh (not including the master cylinders for the brakes and clutch).
I would not expect to pay more than £200 for a later pedal box (note that the later Series 1 are the same as the Series 2).
If you are going to Stoneleigh at the end of the month, I know that Stu (one of the vendors) had a couple on his stand but that was in October.
On a final point, I would urge you to investigate why you don't want to use your original bellows as there are a large number of drivers who swear that once set up properly, they work fine - the key is getting the vacuum correct. Also, if you are going to the expense of doing the restoration properly, you will seriously reduce the value of your car if you carry out modifications (however good) that are irreversible such as a bulkhead change.
Back to top
MarkE
PostPosted: Sat Mar 07, 2009 12:01 pm    Post subject: Reply with quote
Totally agree with the last para. My understanding is that the parts required to restore the bellows servos weren't available for a long time, and as many were starting to leak fluid through, they developed a poor reputation. I'm sure I've read somewhere that the parts are now available (a couple of years ago) and when rebuilt properly are absolutely fine.
The servo won't make any difference to brake fade. They either work or they don't. When a servo fails it may feel like brake fade though! To improve the brakes on an S1 you can fit different callipers, a simple nut and bolt job which is completely reversable.
If you really want originality then insist upon it. Any good restoration company will provide that service, and if they don't, perhaps you may question whether they are working in your interest or theirs. You can always upgrade later if you feel the need to, safe in the knowledge that you're starting off from an original base.
Back to top
neil4444
PostPosted: Sat Mar 07, 2009 2:33 pm    Post subject: Reply with quote
Many thanks for your helpful responses. There's no question as to the reputation of the people doing the bodyshell work. They simply asked me whether I wanted to keep the standard 3.8 S1 bellows or upgrade to the 4.2 servo as they would need to know up front. As stated earlier I'm all for keeping originality but in this case wasn't really sure which way to go as I didn't know enough about the subject. You've helped me reach a quick decision to keep with original S1 set up so I can order my bodyshell Monday morning - yippee !!!
Thanks again !
Neil4444
Back to top
PostPosted: Sat Mar 07, 2009 4:28 pm    Post subject: Reply with quote
Thanks again !
Neil4444
Neil,
who is building your bodyshell?
Back to top
neil4444
PostPosted: Sat Mar 07, 2009 8:11 pm    Post subject: Reply with quote
Robeys.
Back to top
PostPosted: Sat Mar 07, 2009 8:46 pm    Post subject: Reply with quote
neil4444 wrote:
Robeys.
I would be very interested in knowing how you get on with it as I have had 2 built by Hutsons in the past.
I can let you have a copy of my checklist if you think it would be useful as there are so many things that have to be trial fitted before committing to paint.
Back to top
neil4444
PostPosted: Sat Mar 07, 2009 8:56 pm    Post subject: Reply with quote
Checklist would be fantastic. All information greatly received at this stage. I have spoken to Hutsons too.
Back to top
Display posts from previous:
Post new topic   Reply to topic    The 'E' Type Forum - celebrating 55 years of the ultimate motoring icon Forum Index -> Series 1 All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
