Radio panel/instrument panel conflict
Mickey
#1 Radio panel/instrument panel conflict
Post by Mickey » Sat Aug 29, 2020 1:47 pm
Good morning! This is my first post here and it seems an excellent resource. I recently acquired a beautifully restored '69 FHC. There is very little that needs to done to this car. But it seems the very tight fit of the radio panel/surround obstructs the proper opening of the instrument panel and the fuse blocks cannot be accessed. Has anyone else had a similar experience and how was this issue resolved? Thanks!
Mickey
#2 Re: Radio panel/instrument panel conflict
Post by christopher storey » Sat Aug 29, 2020 2:37 pm
Welcome to the board !
Yes, it's a very common problem, which is more easily solved on an S1 car, by putting thumbscrews on the legend strip at the base of the drop-down panel, so the the strip can be removed in perhaps 20 seconds. This solution cannot be used on an S2, as I assume yours to be, and the real solution is to reduce the amount of padding etc under the radio console so that the console sits lower, at the level it was intended to adopt when the car was new. There is a lot of trial and error involved in this process
Mickey
#3 Re: Radio panel/instrument panel conflict
Post by Mickey » Sat Aug 29, 2020 3:18 pm
Wow... very prompt response to my request. I had decided trimming the bottom of the surround is what would likely be necessary. Will I have to get behind the radio panel to removed the radio surround or can the surround be removed from the front? If from the front this will be easy... from the back, not so much.
THANKS for the reply!
Mickey
#4 Re: Radio panel/instrument panel conflict
Post by christopher storey » Sat Aug 29, 2020 6:21 pm
The surround should usually be secured by 4 nuts ( often dome headed ) on studs at the top and bottom of the forward sides of the radio console. Once these fastenings are removed, it is usually necessary slightly to splay the forward "wings" of the console to clear the studs, and the console should then be capable of being withdrawn upwards and rearwards
#5 Re: Radio panel/instrument panel conflict
Post by malcolm » Sun Aug 30, 2020 8:38 am
Hi Mickey, and welcome to the forum! It's a great resource with some very knowledgeable people.
Some pics of your car would be good when you can get round to it.
Mickey
#6 Re: Radio panel/instrument panel conflict
Post by Mickey » Sun Aug 30, 2020 12:30 pm
Thanks, Malcolm... will post pics soon.
Mickey
Mickey
#7 Re: Radio panel/instrument panel conflict
Post by Mickey » Thu Sep 24, 2020 5:58 pm
Update: The radio panel/surround in my '69 series 2 FHC was fitted so tightly the instrument panel would not open. After removal of the radio panel for correction, I found the left hinge hex bolt from the instrument panel missing. Can anyone provide the size/thread ratio for a replacement? Thanks!!
Mickey
tim wood
#8 Re: Radio panel/instrument panel conflict
Post by tim wood » Fri Sep 25, 2020 9:51 am
This maybe what you need.
https://www.ebay.com/itm/1670-Jaguar-XK ... 3054773089
Above is a US supplier you will be able to get them in the U.K. but I couldn’t at this time locate part numbers
Edit
Found it on SNG Barrett
https://www.sngbarratt.com/English/#/UK ... eBranch=UK
You may need the plastic top hat collar.
Mickey
#9 Re: Radio panel/instrument panel conflict
Post by Mickey » Fri Sep 25, 2020 3:18 pm
Good evening... many thanks for the links. I ordered from SNG Barratt USA this morning. This forum is great!!
Mickey
