The seam on the rear wing to sill joint would concern me. That along with the poor sill end to wheel arch joint .
The car has had new sills I think. ( no bad thing - most have)
The extra door lock mentioned is standard fit on series 1 2+2 which don’t have the key in handle set up on the SWB cars.
Tim
Independent inspection
#21 Re: Independent inspection
#22 Re: Independent inspection
Hi if you need a inspection give me a call on 07778807739
Rob 1972 s3 roadster
Aston Martin DB9 Volante
#23 Re: Independent inspection
Hi Mike,
Has your insurer accepted an agreed value of £90k?
Bob
Bob
Bob
'71 S3
'71 S3
flatfloor 3.8
#24 Re: Independent inspection
Way too much money to pay for this car. I would bale out now and try and get your deposit back.
Bill S1 3.8 OTS.
Mikehalliday
Topic author - Posts: 14
#26 Re: Independent inspection
Thanks everyone for your help, I’ve taken madjack up on his offer to inspect the car with me, job done cheers
#27 Re: Independent inspection
I've come late to this but I agree the price is too high.
I worked for about 10 years with a company that restored E types exclusively, and superficially that car looks pretty well done to me. I agree the panel line between the wing and the sill looks wrong. The bonnet and door fit can probably be adjusted out.
#28 Re: Independent inspection
Hope this worked out well. Any news after the inspection? Are you happy with the car as that is, ultimately, the most important thing.
Best wishes, Chris
Best wishes, Chris
Chris
1963 3.8 FHC
1963 3.8 FHC
