Unidentified switch
meeka
New Zealand
#1 Unidentified switch
Post by meeka » Fri Feb 24, 2012 7:22 pm
I'd be grateful if someone could help me identify the function of the switch to the left of the brake warning light. I suspect "Hazard Light" but currently it is dormant.
Graham
vipergts
Post by vipergts » Fri Feb 24, 2012 7:51 pm
Aftermarket fitment I think
S1 4.2 Roadster in Resale Red
Post by abowie » Fri Feb 24, 2012 8:59 pm
I agree; it doesn't look factory to me. One possibility is that it is wired to the radiator fan(s) as an override. The little red light next to it looks the same as the choke light on my car which has series 2 dash, albeit in the wrong place.
meeka
New Zealand
Post by meeka » Sat Feb 25, 2012 11:26 pm
Thanks to you both. I suspect you are correct, now that I have a closer look - so time to start tracing.
Bob Falfa
Post by Bob Falfa » Sat May 05, 2012 8:08 pm
I've seen a similar switch (rotary) which varies the speed of the wiper motor.
E Type Club & JEC member
meeka
New Zealand
Post by meeka » Sun May 06, 2012 5:47 am
Thanks, Bob.
I'm out of the country at present, but will check that option when I return.
Cheers, Graham
1968 1.5 2+2
1954Etype
Post by 1954Etype » Sun May 06, 2012 7:37 am
meeka wrote:Thanks, Bob.
Cheers, Graham
Graham my money is on fan override. The red indicator light telling you the fan is running.
Either way, let us know.
Angus 67 FHC 1E33656
61 OTS 875047
