S3 Servo reservoir overflowing draining from master res
gardnerz1
#1 S3 Servo reservoir overflowing draining from master res
Post by gardnerz1 » Tue Aug 15, 2017 6:51 pm
My series 3 v12 servo reservoir overflows as the master reservoir level drops. Where should i start looking? I replaced the master with one from SNG Barrett and rebuilt the servo.
#2 Re: S3 Servo reservoir overflowing draining from master res
Post by MarekH » Tue Aug 15, 2017 7:37 pm
Sadly, your servo rebuild was not successful and the seal on the shuttle in the servo is leaking.
You may get some joy by filling reservoir with red grease and rebleeding, or it may continue to leak past the seal.
Most likely you will need to replace that seal, make sure it is well lubricated and check that the bore is free from impediments and smooth.
I have relocated my second brake reservoir to be at the same height as the master to forestall this eventuality. If it were to leak, it'd be slow enough not to cause damage as there is no level difference to encourage the brake fluid to move rapidly.
#3 Re: S3 Servo reservoir overflowing draining from master res
Post by PeterCrespin » Wed Aug 16, 2017 12:37 am
MarekH wrote: If it were to leak, it'd be slow enough not to cause damage as there is no level difference to encourage the brake fluid to move rapidly.
I suspect that servo accumulation of fluid is typically due to vacuum rather than gravity.
