#1 Presentation
Posted: Thu Oct 21, 2021 4:32 pm
by JO-44
Hello everyone,
Frenchie, Brittany region, I have an XKE 4.2 from 1969. For some time my brakes have been sticking hot for a short time. I noticed while browsing the forum that this is a broad topic. So I will go through all the posts dealing with the subject to try to find a solution to my problem. Thank you for all these topics covered here
#2 Re: Presentation
Posted: Thu Oct 21, 2021 5:41 pm
by Gfhug
JO-44, welcome to the best place for all things E Type. Ask questions, use the search feature and review what’s in the knowledge base and you should find your answers.
Please add your name to the signature area so we can respond using your name in a much friendlier way and add you car model as it will help people answer your questions with the relevant information. Lots of friendly help here.
#3 Re: Presentation
Posted: Thu Oct 21, 2021 9:09 pm
Check your reaction valve first.
#4 Re: Presentation
Posted: Sat Oct 23, 2021 7:41 am
by JO-44
- VIGNETTE XKE.jpg (107.06 KiB) Viewed 6469 times
- VIGNETTE XK120.jpg (212.68 KiB) Viewed 6469 times
OK I added to the profile for better discussion.
Regarding the brakes of the 1969 XKE the translation is incomplete. No overheating of the front brakes. When I release the brake pedal, the brakes do not immediately release. I see a lot of identical issues on the forum. I continue my investigations. Good day
#5 Re: Presentation
Posted: Sat Oct 23, 2021 10:03 am
by christopher storey
If there is no overheating of the front brakes but the rears are sticking on, then the likely cause is that the rubber hose between the body and the rear suspension unit has collapsed internally . The effect of this is that the hose operates as a one-way valve, allowing pressure to be applied to the rear cylinders , but preventing it being released
#6 Re: Presentation
Posted: Sat Oct 23, 2021 11:32 am
by JO-44
christopher storey wrote: ↑Sat Oct 23, 2021 10:03 am
Hello Christopher, and thanks for the analysis. I have already bought the replacement hose from Baratt. I'll replace that. What do you think of the Fosseway kit to more easily bleed the rear brakes?
#7 Re: Presentation
Posted: Sat Oct 23, 2021 12:12 pm
by Gfhug
Jo, I have an easy bleed kit on my rear brakes and certainly find it very useful
#8 Re: Presentation
Posted: Sat Oct 23, 2021 5:33 pm
by Polse7317
Hi JO i have a kit fosseway that i don't use anymore....PM if you are interested ?
BTW i have to search it among all my mechanic stuff
