#1 Hello from Tulsa, OK
Posted: Mon May 16, 2022 1:27 pm
Hello everyone. So I’m working on my neighbors 1973 V12 convertible. It hasn’t run for 12+ years. Neighbor installed a new fuel pump in the last year or so. He was nice enough to prep car for me. Get in on stands, remove the hood. So I tested the pump, fixed a few leaks, confirmed fuel to engine, charged a battery multiple times, confirmed spark, and with lots of starter fluid (and battery charges) got it running. The more it ran, the better it ran. Balanced the carbs a little bit (floating ball tool), bled front brakes and even took it for a short spin. Very exciting. So now, I’ve replaced all coolant hoses, belts, front shocks, dropped the rear IRS cage to replace brakes, rotors, and shocks, install remote bleed lines, and clean it up.
Speaking of brakes, why is it impossible to get a new piston in the front caliper after inserting a new seal……I wasn’t expecting that to be what breaks my spirit working a Jaguar for the first time. Is there a special trick or tool I’m missing. I tried a block of wood and hammer to push it in and all that did was cut the seal……Strike 1.
