#1 OTS soft top centre clip
Posted: Thu May 26, 2022 1:20 pm
by Mindcorp
Hi guys. Andrew here. New to the forum. One of my e types has a problem with the centre clip on the soft top. I have fixed the issue with water ingress (am happy to share the solution, not the inner tube one), but I think over time my hood has probably shrunk slightly and whilst the side clips are seated perfectly, the centre clip will pop up do to undue pressure. The front of the hood as it joins the chrome, looks to be bowing slightly inwards in order to make the clip connect. I don’t want to take the hood cover off unless I have to. I have tried adjusting the clip hook length, but again it pops open when the metal plate genuflects back to its flat shape. Any help gratefully received.
#2 Re: OTS soft top centre clip
Posted: Thu May 26, 2022 5:41 pm
by Gfhug
Andrew, which series car? I believe there were changes to clips over the years.
You’ll notice further reading below, why not look through those, maybe they will give you some ideas.
As for your leak fixes, please let us know. One of the great benefits of this forum is the ready and open sharing of information.
Also, please add your name and car types to your signature area, this helps those who have the knowledge to answer appropriately.
Good luck
