Tachometer Reading
Brinsley
#1 Tachometer Reading
Post by Brinsley » Mon Jul 10, 2023 12:32 pm
I have recently converted my series 3 v12 etype to 4 port electronic injection but have encountered a problem with generating a correct tacho signal
During installation the ballast convertor and amplifier were removed as they were not required and the tacho signal was picked up from the negative side of an uprated coil as advised but the out put sends a signal which is only 40-50% of what would be normal.
Should I reintroduce the amplifier in the circuit to boost the tacho signal and if so how. Or is there another method to get the correct signal.
Ian
Iansparky
#2 Re: Tachometer Reading
Post by Iansparky » Tue Sep 05, 2023 7:07 pm
Send an email. To clocks4lassics, he is very helpful and knowledgeable about getting our tach to run with electronic ignition
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
madjack4
#3 Re: Tachometer Reading
Post by madjack4 » Sat Sep 09, 2023 8:01 pm
Hi i have converted my s3 to electronic fuel injection u need a resister wired in wire between coil and tacho signal wire if u need to fit one i will check on ebay to see what resistor value i fitted
Rob 1972 s3 roadster
Aston Martin DB9 Volante
