I plan to use orginal triple SU carbs, stock induction system with ITG filter, very lightly ported head, standard size sainless valves, 9:1 compression, probably piper fast road cams, cast exhaust manifold and Classicfabs Big Bore pipes. Gearbox will be original 4-speed and the diff will have 3.07:1 ratio. Front brakes will be upgraded to Wilwood or AP Racing kit.
That's the plan for now however it's not final...
