I'm in Switzerland and intend to become an OTS Series I owner.
I've informed myself a little from various sources, but would very much welcome advice from the pool of knowledge and experience on here about a couple of things.
Rust(!)
Firstly, having looked at a few OTS that are for sale, I'm very concerned by the prospect of "hidden rust" within the monocoque section ? especially when I can see rust on most examples.
Incidentally, it seems that "perfect body" and "no rust" are terms that are used quite casually by some vendors!
If an inner sill/floor seam looks like this, is it not wiser to just walk away?
or is this really fairly insignificant and easily halted/remedied?
Outer panel joints
Is an intact sill to A-post or rear wing joint only seen on freshly resprayed cars?
One with ? more or less ? "original" paint, had cracks at the A-post to sill and at the rear wing to sill areas on both sides of the car and the vendor insists that this is inevitable...
I know that original paint allows a better assessment of a car's condition ? and that the seams by the rear plate are often filled on re-sprays, but does this original one really look OK ? or is it about to start crumbling away?
Oil pressure
I've seen it said that oil pressure when warm, at idle, should be 40+ psi. I've also read that the oil pressure gauge is notoriously unreliable.
I have driven one car that had just over 40psi after a long run, but another two that also seemed to run well though they only showed 20 psi and the vendors said that they were fine... are these bargepole jobs ? what is the truth?
Rims/tyres
This one is not so important, but I may as well ask whilst I'm at it. I don't intend to push the car particularly hard, but I'd like a predictable response. Is it true that the stock rims with Dunlops offer the most progressive and pleasing handling. The cars I've driven have all been on standard width rims with old and questionable rubber. They seemed to struggle somewhat in corners, though the car seemed to be quite benign ? at least with power-induced loss of traction.
The OTS does seem to "teeter" in a somewhat unstable manner with its fairly narrow track ? but maybe that is more down to dodgy tyres. One vendor sang the praises of the available wider (6.5" rims) to improve things. Does this not ultimately detract from the driving experience (heavier wheel inputs, less progressive loss of adhesion at the limit, more road noise, heavier fuel consumption, more tram-lining) or does it improve the whole feel (more settled/stable ride, better braking, superior grip). Is there a consensus or is it down to individual preferences? Is there a recommended tyre for the wider rims?
Hope I've not overwhelmed everyone with my questions ? it's just that these cars are going for quite significant sums (sums for which a very solid modern car can be bought!), so I don't want to buy in haste and regret at leisure!
