#1 a 1964 3.8FHC near Paris
Posted: Thu Jul 11, 2013 1:28 pm
Hi Everyone,
I am Hubert 43years living near Paris & very sorry for my poor english!
I am here : http://bit.ly/13Q57qL
I ?ve bought an american Opalescent light Blue FHC, 2 years ago. A lot of work has been done (paint, brakes, electrical, exhaust, suspension, steering, etc?).
Last winter, the motor was 100%redone. A lot of km were done this spring at low speed. Oil pressure, temperature, no leaks, no noise, etc.. : all was ok
The nightmare began last sunday : after 1hour at 1000/2000rpm, I went on the motorway with a GPS in order to check the speedo. After 1 mn at 4500 rpm, a small noise appeared. I immediately slow down at 2000rpm, but the noise went louder and louder. It was a deep noise, like ?clank clank clank?, coming from the motor. I went back at home at low speed. After removing the oil sump, it appears that one of big end bearing was burnt (in French, we say ?couler une bielle??.)
The oil level was ok before starting so I suspect poor quality of the bearings (purchased at SNG)
Did anyone encounter the same problem? Do you know if there are different qualities available for bearings?
The crankshaft has a little scratch, but very small: Do you think I can avoid to send it to the workshop?
Thank you for your help !
