New member Fleet, Hampshire UK with basket case 1962 3.8 FHC
MarkW
#1 New member Fleet, Hampshire UK with basket case 1962 3.8 FHC
Post by MarkW » Fri Sep 06, 2013 11:12 am
Hello Forum! I have recently joined and I am looking forward to benefiting from everyone's restoration experience but first a bit about me... I have had my car for many years but for most of that time it has been in my garage undergoing serious body restoration. Like many people I have had other committments which have got in the way and work has been on hold for too long (and to be truthful I got bogged down with the scale of some of the work). Stumbling across the forum recently and also seeing some of the excellent restoration stories on the web has prompted me to get started again!
So, the car is a 3.8 FHC chassis 860659 registered in August 1962 and will eventually return to the original Opalascent Dark Green but currently undergoing serious metal surgery to front bulkhead, windscreen supports etc. All practical advice and support gratefully received!
June 1962 FHC Opalescent Dark Green (bodyshell currently with Blackline Classics).
Post by Heuer » Fri Sep 06, 2013 11:29 am
Welcome to the Forum Mark!
If you have questions please do not be afraid to ask and if you have the time please consider starting a thread in the 'Restoration Stories' part of the Forum so others can follow your progress and chip in with suggestions. Also check the 'Factory Fit' thread that Angus started as it contains lots of detail on how things were put together originally.
neil4444
Post by neil4444 » Fri Sep 06, 2013 1:03 pm
Hi Mark,
Welcome and look forward to seeing the photos !
Neil
Neil
1962 S1 OTS
1967 S1 FHC
MarkW
#4 Thanks for the welcome guys
Post by MarkW » Mon Sep 09, 2013 2:22 pm
Very encouraging to know the support is out there! I will try some photos but my small garage makes it a little difficult. Serious front bulkhead work in progress at the moment requiring new o/s windscreen pillar after I fabricate new dash panels, box section stiffeners etc...
