smokey_m14
Post
by smokey_m14 » Sun Jan 26, 2014 11:22 pm
8)
I'm trying to get my 1967 jaguar E type 2+2 on the road, i've owned it for 13 years now. The IRS is getting rebuilt first. I have it pulled out
I'm having a devil of a time getting the handbrake compensator off the cage, I tried to turn one of the 2 mounting bolts and its just spinning, I can't quite see up under there but it feels like weld nuts on the inside of the cage, anyone have any insight? I'll probably make a more elaborate post in the technical section on the overall removal restoration of the IRS later!
smokey_m14 on Sun Jan 26, 2014 11:34 pm, edited 1 time in total.
Post
by abowie » Mon Jan 27, 2014 12:33 am
You are correct; captive nuts. IIRC it'a actually a steel plate with 2 threaded holes, but not certain.
If it were me with that amount of rust I'd just cut the bolt heads off.
Durango2k
Post
by Durango2k » Mon Jan 27, 2014 6:00 am
Actually it Looks better then Mine before i tackled it !
Carsten
- Moderator
Post
by 1954Etype » Mon Jan 27, 2014 8:26 am
Cage containing square nuts. You can prise open the cage and get a spanner on the nuts. Give it a good soaking in penetrating oil first.
Post
by MarekH » Mon Jan 27, 2014 8:30 am
If they are not captive, would you not call them "caged nuts"? On the s3 they are very thin and sit inside a pressed steel cage - they may well be loose and able to move, which is why you can't undo them. If this is the case, then a very thin 1/2" spanner will be needed.
