Hi all,
I think I am missing some parts from the luggage area of my Series 1 2 + 2. The problem is that the two floor sections in the luggage area do not sit correctly. There is a "cross brace" between the wheel arches with three saddle type supports welded to it. I think there ought to be another "brace" or support bolted to them.
Is that correct?
Also, I think there should be some fittings to clip the floor pieces into place and /or to lift the floor pieces out.
Is anyone able to help and does anyone know whether the various bits might be available from parts suppliers/wreckers/breakers?
Does anyone have any photos that show what is needed?
Cheers, Roger
2+2 Luggage area issue
Roger's E Type
Topic author - Posts: 46
spanish 2+2
Hi Roger, I have 3 sections on my car, one that fits straight across behind the back seat, a large section over the spare wheel and a smaller panel over the petrol tank. There are no fitting to locate them or hold them together, but on the large panel over the spare wheel there is a finger hole with a chrome ring for removal. Hope this helps.
69 s2 2+2 Signal Red
