https://www.ebay.co.uk/itm/Tow-bar-for- ... rk:44:pf:0
Hitch up the caravan and away you go!!
TheDampMan
Topic author - Posts: 83
#1 Hitch up the caravan and away you go!!
1969 Series 2 Roadster
BMW Isetta
BMW Isetta
#2 Re: Hitch up the caravan and away you go!!
#3 Re: Hitch up the caravan and away you go!!
That caravan would be for quite small people I'm thinking...
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#4 Re: Hitch up the caravan and away you go!!
There’s a S2 FHC down here with a two bar AND a caravan.
#5 Re: Hitch up the caravan and away you go!!
The only reason I would fit a tow bar to an E Type is to pull a Riva Motor Launch.
But then, maybe not......
#6 Re: Hitch up the caravan and away you go!!
#8 Re: Hitch up the caravan and away you go!!
If it's for towing it's probably intended to attach to the front of an E-type.....
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
