Not sure where best to post this.
When I sign in and click " Posts since last vistit" I might get for example 4 new posts within various topics. When I go to "latest post" within said topic then go back to pick up another post within a thread it tells me there have been none since my last visit.
A bit annoying when clearly there has been cos it just told me.
For some technical reason it's not giving me enough time to visit each new post before sensing I've already been visiting with my previous choice......if that makes sense?????
Forum glitch
No idea - never used that feature. I usually just go to the coloured blobs and see what is in there. I will have a look and see what is going on. In the meantime, after you have read the 'latest post', click the back button in your browser which should take you to the list of new posts again. As long as you keep going forwards by clicking the topic and going backwards clicking the 'go back one page' browser button you will be OK. A workaround until I can find a fix.
Still doesn't work if I click back. It assumes I've already had time to look I think or knows I've already been at that stage.
S1 4.2 Roadster in Resale Red
Works OK for me even after I have read the posts (I am using Firefox). Try clearing your browser cache but it seems to be a problem at your end rather than the Forum software. That option uses the search function within the software so you could check that searches work.
OK........I use chrome now so relatively new.
