Tasteful jokes.
- Moderator
Post
by mgcjag » Sat Jan 19, 2019 10:28 am
Hi All....Im currently building a Realm C type replica....if any of you are considering or building then let me know..im part of a very small (9 member)Whatsapp self help group covering all aspects of a build...from is a Realm right for you through to passing IVA & registering....always space for someone new....all the best...more info here
viewtopic.php?f=11&t=14687 Steve
One of our members self builds recently completed
Post
by malcolm » Sat Jan 19, 2019 10:47 am
Looks fabulous! What engine is in it?
- Moderator
Post
by mgcjag » Sat Jan 19, 2019 11:01 am
Hi Malcolm....XJ6 is used as a doner car for engine/ suspension /diff/brakes etc...chassis is tubular from Realm and body glass fibre....lots of options for making it to your own spec....note on this one the carbs have been converted to throttle bodies and its a fuel injected 4.2...Steve
Post
by malcolm » Sat Jan 19, 2019 11:39 am
So a bit quick!
- Moderator
Post
by mgcjag » Sat Jan 19, 2019 12:00 pm
Oh yes......considering that only 53 real ones were built and would cost £5m+ to purchase then a replica is the only way to go for most who want one......you could build for under £30k completed....Steve
Post
by Gfhug » Sat Jan 19, 2019 5:14 pm
Steve, do you mean you haven’t got a spare £5million lying around then
It’ll be good to see your car when it’s on the road. Good luck with getting it finished.
Post
by malcolm » Sun Jan 20, 2019 9:54 am
Does it have a tonneau for when it's left in the rain? Or is that sacrilege?
- Moderator
Post
by mgcjag » Sun Jan 20, 2019 11:02 am
Hi Malcolm....is what sacrilege useing it in the rain or fitting a tonneau
Its up to you...in the 1st photo studs are fitted for a tonneau....but as a self build you can have it as you want.....Steve
Post
by malcolm » Sun Jan 20, 2019 11:32 am
Yeah, meant is it sacrilege to have it out in the rain! I love tonneaus; used to drive my TR4 in snow and ice with the roof off, with a 3/4 tonneau done up and heater on full in the footwells.
What about a hood? Or do you get wet when it rains?
- Moderator
Post
by mgcjag » Sun Jan 20, 2019 12:47 pm
Never seen a C type with a hood......you just get wet
Simon P
Post
by Simon P » Sun Jan 20, 2019 7:22 pm
mgcjag wrote: ↑Sun Jan 20, 2019 12:47 pm
you just get wet
Much like driving an E-type in the rain then....
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
Tony
Post
by Tony » Sun Jan 27, 2019 12:18 am
Would this have to have a Q plate and yellow and white number plates?
Tony (E typed)
Tony
Durango2k
Post
by Durango2k » Sun Jan 27, 2019 8:50 am
How much would such a self - build cost in the end ? It might be an alternative to the Cobra I thought about doing after my E-Type. There‘s a Citroen DS in the line as well, but then, maybe...
Carsten
- Moderator
Post
by mgcjag » Sun Jan 27, 2019 9:40 am
Hi Tony.....no it will not get a Q plate.....It wil get a plate related to the age of the doner car......this is done by useing a kit of parts from a manufacturer (chassis etc) to build useing major parts from the doner vehicle (engine etc)...will be registeted with dvla under a kit converted vehicle..... if you just build your own chassis and use various parts then its a kit car and then yes a Q.........after completing the build it then needs to have an IVA test.....like an all day mot to check the build.....then it can be registered..........i can then put an ageless plate on..
Hi Carsten....the one in the photo above cost less than £30k to complete.......Steve
Post
by christopher storey » Sun Jan 27, 2019 11:01 am
Seen from that angle, the C type has to be one of the most handsome Jaguars built . I still regret not having built a Jim Marland C type in the early 90s, having been distracted by an E type ! The Marland cars ( Proteus in its original guise ) were beautifully made
- Moderator
Post
by mgcjag » Sun Jan 27, 2019 11:09 am
Proteus are in the £150k area now i think for a new one.....Steve
Tony
Post
by Tony » Sun Jan 27, 2019 11:17 pm
Steve, good new not having it as a Q plate as this would ruin it. I thought it was based on a new space frame chassis. Look forward to the rebuild and final result.
Tony (E typed)
Tony
- Moderator
Post
by mgcjag » Mon Jan 28, 2019 9:14 am
Hi Tony...this is the chassis.....upside down ready to fit floor panels (first job)....Steve
Jeremy
Post
by Jeremy » Mon Jan 28, 2019 9:26 am
Wow. Beautiful Steve.
And I used to think that a Caterham was the ultimate kit car...
Jeremy
1967 S1 4.2 FHC
- Moderator
Post
by mgcjag » Sat Nov 11, 2023 9:38 am
Hi All..havent updated this thread for a long time...life and other cars got in the way... the build of the C type is done and just had its IVA test pre dvla registration....the car has to be "comply" for the test...hence exhaust, wheel arches, head restraints etc......unfortunatly it failed....only thing out of my control ....speedo calibration....so fitting a programable unit to set on their rollers at the retest....good thing is at retest they will only check the speedo...so hopefully retest soon..then paint....Steve
