MG Midget Starter Motor
Tasteful jokes.
JerryL770
#1 MG Midget Starter Motor
Post by JerryL770 » Tue Apr 28, 2026 1:24 pm
I know this is not E-type but someone may well be able to advise.
I'm helping a friend who's 1977 MG midget has been having starting problems, identified as being a duff motor.
We have taken it off and I've stripped, cleaned and re-assembled and it still don't work. Nothing inside looked amiss so looking for a replacement motor. This brings my question.
All the ones I found specify it has 9 teeth. I checked the one taken off and it definitely has 10 teeth. There's no undue damage on the teeth.
Will a 9 tooth starter work or give us problems?
Any advice appreciated before we buy.
Ta, Jerry
Jerome Lunt
#2 Re: MG Midget Starter Motor
Post by mgcjag » Tue Apr 28, 2026 2:29 pm
Some use 9 and some use 10 depending on the ring gear...you should use the correct one....this is not E type so will put it in the pub chat section
#3 Re: MG Midget Starter Motor
Post by mgcjag » Fri May 01, 2026 7:48 am
Well I posted a reply to try to help :shrug:
