problem logging in
Tasteful jokes.
Roman K
#1 problem logging in
Post by Roman K » Fri Apr 13, 2012 9:03 pm
Hi all, I have a problem logging in.
I have to log in twice before I get the option "View posts since last visit"
problem is not much happens during that half a second sins my first attempt witch means the result is always nothing :(
Is this a common issue?
Post by Heuer » Fri Apr 13, 2012 11:22 pm
Not that I know of. Please try clearing your browser cache and see if it still happens. I am using Google Chrome and have never had a problem. Please keep me advised if you still have an issue.
wol916
Post by wol916 » Fri Apr 13, 2012 11:58 pm
Happens to me as well, I found that the first time I log in on a particular day if I delete the auto-filled password and type it again that usually works, seems to be OK after that (at least for the rest of the day).
Warren
Warren
S1 FHC 4.2 OSB
Post by Heuer » Sat Apr 14, 2012 10:48 am
Can you try clicking on the 'Log me on automatically each visit:' check box and see if it still happens. I have seen this happen to me in the past but never been able figure out what is going on. Clearing your browser cache usually sorts it out and since I have the auto login checked it has never happened again.
Roman K
Post by Roman K » Sat Apr 14, 2012 1:57 pm
noop, didn't help.
I have tested with ie and safari. Same phenomena.
Strangely every now and then it works but only once.
vipergts
Post by vipergts » Sat Apr 14, 2012 3:02 pm
Happens to me also
I log in automatically and go to "posts since last visit" but I can only choose 1 subject to view taking me to the last post in that subject that I haven't already read. After that any other subject comes up as "Non since last visit?
Had the problem for ages and I have cleared Caches and have chrome.
One of those things I've learnt to live with.....bit like having a car which won't tick over. :lol:
S1 4.2 Roadster in Resale Red
Post by Heuer » Sat Apr 14, 2012 3:52 pm
Just tested it from my end and I can see the two posts since my last visit and view them but I rarely use that feature - I just look for the orange blobs to show me which threads have new material. I will do some more testing now I know what you are trying to do.
vipergts
Post by vipergts » Sat Apr 14, 2012 4:58 pm
Yes that's what I do....click the orange blob which is exactly what I've done here which has taken me to the new material (your post)
Now if I click back to "New Posts" and click the orange blob on any other post it say "There are no new posts since your last vist"
Hope that makes sense :shock:
frogeater
Post by frogeater » Sat Apr 14, 2012 5:47 pm
Hello,
I have the same problem, too.
Post by Heuer » Sat Apr 14, 2012 5:53 pm
What if you don't use the 'back' button but just click on'The E-Type Forum - celebrating 50 years etc' and then go to view new posts?
vipergts
Post by vipergts » Sat Apr 14, 2012 6:28 pm
Comes up with "nothing in your search criteria"
Roman K
#12
Post by Roman K » Sat Apr 14, 2012 7:26 pm
orange blobs ha :idea: thats good news :) now I can start using the forum in limp mode while solving this issue :)
Roman K
#13
Post by Roman K » Sat Apr 14, 2012 7:30 pm
oh, by the way, is it possible to make a search on any new reply on the forum last 24hrs?
Post by Heuer » Sat Apr 14, 2012 8:52 pm
At the moment it seems this is a bug of some sort and there does not appear to be a fix I can find. Suggest you avoid the 'posts since last visit' bit and just view the Forum using the main screen and orange bubbles. Seems to be an issue with the code on 'view posts since last visit' so if it does not work for you, do not use it until I find a solution.
Post by Heuer » Sun Apr 15, 2012 12:49 pm
I have just started using the 'view posts since last visit' function (normally I just scan down the main page and open new posts from within each section. I can't get it to fail - works every time for me!
I will keep experimenting with it using IE and Firefox as well as Chrome and see what happens. If I can't replicate it I can't look for a fix!
vipergts
Post by vipergts » Sun Apr 15, 2012 2:23 pm
Heuer wrote:I have just started using the 'view posts since last visit' function (normally I just scan down the main page and open new posts from within each section. I can't get it to fail - works every time for me!
Well......There has to be something wrong with your computer. :lol:
Roman K
#17
Post by Roman K » Mon Apr 16, 2012 7:39 am
don't seem to get the orange blobs either :(
have now tried on another computer but get the same problem.
I had to log in twice here to.
Post by Heuer » Mon Apr 16, 2012 10:26 am
Roman K wrote:oh, by the way, is it possible to make a search on any new reply on the forum last 24hrs?
No but you can subscribe to a particular thread and you will be emailed to tell you. Its at the bottom left of the page in the thread you are interested in 'Watch this topic for replies'. Can each of you let me know what browser you are using when this occurs please. This is what I see:
Unread threads from the main screen:
View posts since last visit:
So after I have read the first one (Pub Chat) the rest of the unread ones are still highlighted. Now if I were to not read those orange blobbed posts and navigated away from the Forum, even if I returned a few seconds later, the blobs would be gone. This is because "since my last visit" there would probably have been no new posts. So you can't read one or two and come back later to read the rest and expect them to be highlighted. Only way is to open a new tab in your browser for net navigation and leave the Forum tab open.
vipergts
Post by vipergts » Mon Apr 16, 2012 5:13 pm
I use chrome
If I read an unread post then go "back" to look at the other unread posts I can't see the unread posts....just says "nothing in my search criteria"
Furthermore to add to my frustration today I had to log in whereas normally its automatic. Then when I logged in and clicked unread posts it tells me there aren't any when if I do a manual search there clearly is.
Roman K
#20
Post by Roman K » Mon Apr 16, 2012 5:18 pm
Explorer 9 and safari 5.1
