Hi there
If anyone can help me with advice.
Has anyone changed there headlights to series one fixed, on a series 2 bonnet. Mine is a series 1.5
Series 2 bonett and a 1 everywhere else.
So want to get a kit. What’s the best one, and is it possible to do.
Thank you
Harvey
New head light kit series 1
Harveysearle
Topic author - Posts: 116
Harveysearle
#4 Re: New head light kit series 1
Have to admit, I'm really starting to like the 1.5 a lot! And I have two covered series 1s.
Kingkitesurf
#5 Re: New head light kit series 1
I did the change over. I have a 68. Managed to buy a set original covered lights from ebay 7 years back. Monocoque metalworks sells the surrounds that you have to weld in. You do have to do some welding though. I managed not to have to repaint the whole car or not even the bonnet. Just spot repair respray with a custom aerosol around the lights and then blemished it out with Commandant4 and polish. Great result. It was a significant job to do anyway. Took me 3 days to make it look good. Here is a pic.
Job
1968 E-type 4.2 S1.5 FHC
Harveysearle
#6 Re: New head light kit series 1
Thank you
So what do I need to order from them
Do I need the whole kit
Cheers Harv
Cheers Harv
max-it-out
#7 Re: New head light kit series 1
I think it might be possible to just use pop rivets to fix the inserts from MMW .
1968 series 1.5 roadster
Harveysearle
#8 Re: New head light kit series 1
I def can’t use the light inserts from my s2 can I ?
