Nuts & Bolts
thermojac
#1 Nuts & Bolts
Post by thermojac » Tue Oct 13, 2020 3:36 pm
Very basic question but how do I go about finding supplier for missing nuts & bolts as all my stock is metric?
S3 FHC 1972 Manual
#2 Re: Nuts & Bolts
Post by mgcjag » Tue Oct 13, 2020 3:38 pm
Google is a good place to start.....sngb will have most you will need and other suppliers...Steve
tim wood
#3 Re: Nuts & Bolts
Post by tim wood » Tue Oct 13, 2020 3:40 pm
I use Spalding nut &bolt on eBay. Excellent service and prices seem reasonable
For jaguar specific stuff then I use Win Perry (wjperry) also on eBay.
No connection to either other than as a customer
thermojac
#4 Re: Nuts & Bolts
Post by thermojac » Tue Oct 13, 2020 3:53 pm
Thanks guys, very helpful.
So how do I identify what size I need if bolts/screws are missing e.g. 2 screws holding stay arm to tail gate?
S3 FHC 1972 Manual
#5 Re: Nuts & Bolts
Post by rswaffie » Tue Oct 13, 2020 3:59 pm
Some of the parts suppliers list the sizes, as does the Jaguar parts catalog in most cases.
Kember17
#6 Re: Nuts & Bolts
Post by Kember17 » Tue Oct 13, 2020 5:35 pm
Chuck is the gent who runs this show:
http://www.monocoque-metalworks.com/main/
He sells sets of top quality fasteners...
I write as a happy (UK/EU) customer but with otherwise no connection.
Peter
EDIT: He's also forgotten more about how E-types are put together than most of us will ever know.
Peter
1966 LHD US Import Series 1 2+2 (undergoing full restoration)
1991 LHD Alfa Spider Series 4
2015 Porsche Panamera S
#7 Re: Nuts & Bolts
Post by rswaffie » Tue Oct 13, 2020 6:01 pm
Yep, I purchased one of his comprehensive kits.
I retained all the original non-high tensile Bees fasteners where they could been seen.
Kember17
#8 Re: Nuts & Bolts
Post by Kember17 » Tue Oct 13, 2020 6:04 pm
They are exceedingly good value and, for quality, are the veritable mutt's in my opinion.
P
Peter
#9 Re: Nuts & Bolts
Post by christopher storey » Tue Oct 13, 2020 6:22 pm
The parts catalogue for your specific model is an absolute essential if you are missing many fasteners . The individual fasteners have numbers which contain a code to denote their type, thread and length. Thus purely by way of example the setscrews which hold the headlamp scoops in are 2 of UFS 119/6R and 4 of UFS119/8R which means UNF thread in size, setscrew , 1+ hexagon, 19 is diameter in 100ths of an inch ( this equates to 3/16) 6 means 6/8 inch long and r means wrench driven
The codes are given on this list
http://www.e-type-lovers.com/memberfiles/fasteners.pdf
I hope this will help
#10 Re: Nuts & Bolts
Post by rswaffie » Tue Oct 13, 2020 6:33 pm
:yeahthat:
I printed off the nuts,bolts,washers etc codes from the forum and covered the pages in plastic film as I used them so often (in conjunction with the various spares books) to get the correct items.
Invaluable!
thermojac
#11 Re: Nuts & Bolts
Post by thermojac » Tue Oct 13, 2020 10:44 pm
Excellent contributions from all. Thanks very much and very much appreciated. Looks like I have some researching and buying to do :-)
S3 FHC 1972 Manual
AshM
#12 Re: Nuts & Bolts
Post by AshM » Thu Oct 15, 2020 11:20 am
For a general stock of imperial nuts, bolts, washers, etc I use Namrick John.
Very efficient service and good quality products.
All the best
Ash
Series 2 FHC 1970
1R 20607
Moeregaard
#13 Re: Nuts & Bolts
Post by Moeregaard » Thu Oct 15, 2020 2:34 pm
For really high-quality fasteners, check with Aircraft Spruce & Specialty. AN (aircraft)-grade fasteners are SAE UNF threads and the quality is superb. I prefer to use AN-grade hardware in critical applications. Surprisingly, prices aren't too far beyond the hardware-store stuff. ACS is based in California, but they have UK and European subsidiaries.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
thermojac
#14 Re: Nuts & Bolts
Post by thermojac » Thu Oct 15, 2020 6:56 pm
Christopher, I downloaded the parts catalogue from E-type parts, which is very detailed, but they only give part numbers rather than the detail spec that you indicated to use with the Fastener ref guide. Is there a better catalogue around?
S3 FHC 1972 Manual
Mephistopheles
#15 Re: Nuts & Bolts
Post by Mephistopheles » Fri Oct 16, 2020 8:18 am
John, SC parts and Limora give detailed specs of bolts, nuts etc.
Holger
1973 manual LHD OTS E Type
Holger
#16 Re: Nuts & Bolts
Post by mgcjag » Fri Oct 16, 2020 8:38 am
Hi John.....an official Jaguar parts catalogue for your model will list every part...as mentioned in Christophers post above......Steve
#17 Re: Nuts & Bolts
Post by christopher storey » Fri Oct 16, 2020 10:03 am
Yes, sorryI I should have made it clear, it is the official Jaguar Parts catalogue, widely available as a reprint, which has all the details . The various vendors' catalogues are not as comprehensive
#18 Re: Nuts & Bolts
Post by Series1 Stu » Fri Oct 16, 2020 5:31 pm
Also download the document Christopher linked to in post #9 - one of the most valuable documents you will use for your Jaguars.
V12 Epyte
#19 Re: Nuts & Bolts
Post by V12 Epyte » Fri Oct 16, 2020 6:44 pm
Westfield Fasteners , near Aylesbury are a another good supplier of Nuts and Bolts Etc. All Online usually dispatched same day.
https://www.westfieldfasteners.co.uk/UNF.html
1971 Series 3 FHC 2+2 RHD Manual
1971 Series 3 Roadster 2+2 RHD Manual
1986 Rover SD1 Vitesse Twin Plenum
thermojac
#20 Re: Nuts & Bolts
Post by thermojac » Tue Oct 20, 2020 10:03 pm
Thank you to all for your very valuable feedback. I appreciate you taking the time to respond. I now have the Fastener Guide and a list good recommended suppliers. Now just got to get hold of an official parts list which is being a bit elusive at the moment.
S3 FHC 1972 Manual
