2+2 dimensions
Phil2+2
#1 2+2 dimensions
Post by Phil2+2 » Fri Oct 20, 2023 11:02 am
Hopefully someone is in the garage at the moment with their 2+2 and could measure how long the car is from back bumper to front of the front wheels
I’m losing the garage where my etype project lives and have the option of a garage that is only 4.35m long so I’m considering removing the bonnet and hoping that the car on its castors will fit?
Can someone help here to save me the drive out to where the jag lives?
Sven
#2 Re: 2+2 dimensions
Post by Sven » Fri Oct 20, 2023 1:30 pm
Hi Phil,
If you work on 4.1m, you should just get the garage door closed!
Good luck :bigrin:
1967 2+2...now in less than a thousand pieces!... :wrench:
Stevejaguar
#3 Re: 2+2 dimensions
Post by Stevejaguar » Fri Oct 20, 2023 1:46 pm
Just measured mine and its 4.1m.
Tight squeeze, good luck.
Phil2+2
#4 Re: 2+2 dimensions
Post by Phil2+2 » Fri Oct 20, 2023 7:49 pm
Gentlemen,
Thankyou very much indeed you've saved me a trip out in the dark with a tape measure.
Ill photograph it once its all tucked up.
