Connecting a trickle charger
Mart
#1 Connecting a trickle charger
Post by Mart » Sun Nov 26, 2023 7:42 pm
After 18 years of ownership I discover what I think is an Optimate SAE71 style charger lead curled up behind the binnacles. It would surely be much easy to keep the battery topped up in winter without having to angle the hood open!
But I'm struggling to find how to connect it to my CTEK XS800 trickler. Ths has what I think is called a "comfort connector"
I've attempted to attach photos of each attachment.
My preferences are buy an adaptor gold , buy a different charger silver and mess unmecessarily with anything in the car a very distant bronze.
I can't find a suitable adaptor on the web. So what do you wiser people recommend?
#2 Re: Connecting a trickle charger
Post by mgcjag » Sun Nov 26, 2023 7:53 pm
Befor I plugged a charger into it I'd make sure its connected to the battery...strange place to have a charge socket as you then need to have the charger lead running through the door?
Robbiee
#3 Re: Connecting a trickle charger
Post by Robbiee » Sun Nov 26, 2023 9:49 pm
I have a CTec leads permanently attached to the battery terminals
When I plug the ctec in the lead comes forward over the soft rubber strip into the front wheel well
Mart
#4 Re: Connecting a trickle charger
Post by Mart » Mon Nov 27, 2023 5:59 pm
mgcjag wrote: ↑
It's a soft top, so either top off or windows open. I will check as you recommend. Any thought on what adaptor i need, assuming that it is indeed connected?
#5 Re: Connecting a trickle charger
Post by mgcjag » Mon Nov 27, 2023 6:46 pm
Your photos show 2 different plugs...doubt you can find an adaptor that fits both...but who knows..I would rewire a socket by the dash to fit your ctek plug....Steve
edriver
#6 Re: Connecting a trickle charger
Post by edriver » Mon Nov 27, 2023 7:39 pm
Hi Mart,
the vehicle side connector seems not to be an SAE 71 style connector. If it would be one, then Ctek sells the interface Artikelnr. 56-564. The best pictures are on Amazon
https://www.amazon.de/CTEK-Anschlusslit ... 2233290675
It comes with a battery charge indicator. Maybe that you find a match for SAE71 to what you have found in the dash.
Klaus
Klaus
#7 Re: Connecting a trickle charger
Post by malcolm » Tue Nov 28, 2023 9:08 am
I just crocodile clip onto the battery. Doesn't take a tick to open the bonnet.
david.coan
#8 Re: Connecting a trickle charger
Post by david.coan » Tue Nov 28, 2023 8:40 pm
My trickle charger goes into my cigarette lighter,ctek charger and buy the adaptor
https://www.ctek.com/uk/battery-charger ... t-cig-plug
So easy to remove before a drive and re instate when i park her back in the garage.
David
caveman
#9 Re: Connecting a trickle charger
Post by caveman » Tue Nov 28, 2023 9:11 pm
If you’ve got a tow bar :lol:, here’s another CTEK option;
https://thomasperformance.co.uk/brands/ ... le-charger
1965 S1 4.2 FHC (early)
:wavegreatbritain:
