SNG throttle cable conversion
paulsco
#1 SNG throttle cable conversion
Post by paulsco » Sat Dec 09, 2023 1:24 pm
I was considering making my own throttle cable conversion as I cannot justify the expense of the SNG one, but just thought I would check the current cost of the real thing.
I noticed from the web site that it is marked “no longer available “
Does anyone know more about this?
#2 Re: SNG throttle cable conversion
Post by bitsobrits » Sat Dec 09, 2023 2:18 pm
I did my own cable conversion, and it's not terribly difficult, especially if you worked as a bicycle mechanic during your college years :bigrin: In terms of functional improvement over original design, I would rate it one of the best mods you can do, but then I have a LHD car with it's very Rube Goldberg (Heath Robinson?) layout.
Also did a couple of other non critical related mods (one piece connecting shaft and spherical joints at the carb lever arms) that helped with smoothness and synchronization of the throttle plates.
#3 Re: SNG throttle cable conversion
Post by Gfhug » Sat Dec 09, 2023 2:39 pm
Look at a couple of the topics below and these:
viewtopic.php?f=9&t=11589
viewtopic.php?f=9&t=6245
E600
#4 Re: SNG throttle cable conversion
Post by E600 » Sat Dec 09, 2023 4:55 pm
Made my own for RHD for Webber’s….
paulsco
#5 Re: SNG throttle cable conversion
Post by paulsco » Sat Dec 09, 2023 9:49 pm
Thank you all for you advice,
Steve, what did you use for the ball joint that attaches the cable to the ball on the accelerator pedal leaver?
At first I thought it was one of the old control rods, but on closer inspection they are different.
E600, does your accelerator leaver attach to both cables, or is it one cable pulling two Cables via the two pulleys?
Unfortunately It is not easy to tell from the pictures.
Thanks again,
#6 Re: SNG throttle cable conversion
Post by bitsobrits » Sun Dec 10, 2023 12:49 am
It's a common linkage rod/cable accessory available in various forms: https://secure.chassisshop.com/partdetail/C90-044/
https://tinyurl.com/balljointlink
To connect to this, I gun drilled a cut down 10-32 brass screw then passed the cable through, upset the end, and soldered in place.
paulsco
#7 Re: SNG throttle cable conversion
Post by paulsco » Mon Dec 11, 2023 12:12 pm
Hi Steve,
Good information and very useful. l will look into all the options before proceeding.
Thanks for your help, much appreciated.
