Hi All
Is it OK to rest the bonnet on its back after removal, I am planning to remove all the old underseal and repaint the underside. I would potentially make a timber frame with foam to protect the paint
Ian
Bonnet/ hood removal
#1 Bonnet/ hood removal
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
2016 Caddy van
#2 Re: Bonnet/ hood removal
Stand it up on its opening end is typical...on a piece of old carpet to protect the edge....iv done it to remove all the underseal and repaint....you could lay it on its back but you would need to be ultra carefull if its painted and avoid damaging the louvres..... Steve
#3 Re: Bonnet/ hood removal
OK, thanks, will give that a go
1965 series 1 ots
2016 Caddy van
2016 Caddy van
#4 Re: Bonnet/ hood removal
And it easy to remove the bonnet on your own as outlined here:
viewtopic.php?f=3&t=6058&p=42910&hilit=Bonnet#p42910
#5 Re: Bonnet/ hood removal
Superb thanks
1965 series 1 ots
2016 Caddy van
2016 Caddy van
