Daytime lights in Europe
#1 Daytime lights in Europe
I live in Europe where daytime running lights are mandatory. We drive a BMW as a daily car, start it up and the lights come on, as a consequence I tend to forget when in the Jaguar.
Has anyone modified their car to bring side lights on automatically at start up, or should I just put a sticker somewhere to remind myself.
David
1973 S3 2+2 in Regency Red
#2 Re: Daytime lights in Europe
Haven't done it myself but seems to be quite a straight forward mod to work out if you have the electrics diagram. Probably no more than moving one wire.....I would also change the front and rear bulbs to LEDs.
#3 Re: Daytime lights in Europe
David, if you search on here for “drl” you will find quite a few responses. If you need the full headlight on not just the side lights then a suggestion is to replace the headlight bowls with ones containing a sidelight with a led which will give a good brightness for you.
This might help:
viewtopic.php?f=9&t=3539&p=23785&hilit=Daylight#p23785
This might help:
#4 Re: Daytime lights in Europe
Upgrade front and rear side lights to LED bulbs and headlights to halogen etc. Don't go too bright as it will cause issues for other drivers at night. Manually switch them on, with a sticker to remind you, and fit a warning buzzer to the side light circuit that comes on with door opening (via the ground/neg side). This will ensure you don't leave them on when exiting the car and potentially flattening your battery, over time.
1965 S1 4.2 FHC (early)
#5 Re: Daytime lights in Europe
Thank you everyone. LEDs are a good move regardless, although I doubt I will drive the car much at night, especially as my current DK classic insurance does not cover road use during the winter months.
I am fitting a new radio next week, it will be a good opportunity to look at the lighting circuits at the same time.
David
#6 Re: Daytime lights in Europe
Surely you’re not required to retro fit daytime running lights in Europe to pre 2011 cars
so yes you can modify your car so they come on at start up, but the age old method of the driver judging what lights are required for the conditions apply to older cars, don’t they ???
Darryl
#7 Re: Daytime lights in Europe
#8 Re: Daytime lights in Europe
Indeed it is, I had a old 60's racing car which was road registered, you really are alert anyway because of it, but we're talking lights. There is no switch order to the lights, they all have their own switch, so you can select what you want, headlights with or without sides, but the most useful was the ability to use the lower mounted spot lights without main beam and in Fog this was just extraordinary, the whole road was lit from the base of the fog and this would project light so far you might as well had been driving on a sunny day, without the main beams giving a useless face full of haze.
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
#9 Re: Daytime lights in Europe
That is a really good point actually. I have noticed a couple of 70s cars without lights on recent. I will ask the question.dlgis wrote: ↑Thu Jun 05, 2025 5:46 pmSurely you’re not required to retro fit daytime running lights in Europe to pre 2011 carsso yes you can modify your car so they come on at start up, but the age old method of the driver judging what lights are required for the conditions apply to older cars, don’t they ???
David
#10 Re: Daytime lights in Europe
I've driven thousands of miles across Europe in France, Spain, Germany, Belgium, Netherlands - never once have I put lights on in the day in my E and never once was I stopped and queried. Been stopped by a few Gendarmes and Polizia who said "Nice car", but never mentioned lights.
#11 Re: Daytime lights in Europe
Since I replaced my side and rear lights with LEDs and added the brake light conversion to the reverse lights, I always drive with sides on which are bright enough to identify as DLRs
ralphr1780
#12 Re: Daytime lights in Europe
I do the same, with buzzer fitted to door light switch.
Ralph
'69 OTS + '62 OTS - Belgium
#13 Re: Daytime lights in Europe
My car spends most of its time on the road in a highly polished condition. DRLs would not increase its visibility by much. That said, I do find myself switching the dipped headlamps on when passing through shady woods or tunnels, and switching them off again. I’ve noticed many modern cars doing the same automatically, probably unnoticed by their drivers.
I also use dipped headlamps when driving out of the rising or setting sun. I’ve done this for decades, since the first days of Volvos fitting DLRs in the 1970s. Then my only vehicle had just two wheels. To be seen in the shadows was a matter of survival.
I have LED sidelights at the front. They aren’t hugely bright, not like today’s LED DRLs.
#14 Re: Daytime lights in Europe
I used a DRL controller module and LED sidelight bulbs. The module was under £10 and very easy to wire in. The LEDs are bright enough and the module power them when the engine starts and stops after 10 second after the the engine stops.
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
"You only live once, but if you do it right, once is enough..."
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
