Where did the fuse go
#1 Where did the fuse go
When you drop a fuse from position 6 or 7 on the RH banks, where does it go and can it be retrieved?
#2 Re: Where did the fuse go
Danny, pick the car up, turn upside down and shake vigorously!
Sadly they can fall anywhere. I use a short, insulated hook to pull a fuse out at one end then it can be pulled out more easily. They are a PITA to pull out.
#3 Re: Where did the fuse go
Check the bottom, or furthest edge, of the hinge instrument panel. Modern glass fuses can be slightly longer so I slide them along slightly, by squeezing with fingers, then lever out at one end before pulling clear. It helps if youve got piano fingers
Good luck.
1965 S1 4.2 FHC (early)
#4 Re: Where did the fuse go
