Metalastik 17/903 4 steering rack mount
Simon2824
#1 Metalastik 17/903 4 steering rack mount
Post by Simon2824 » Fri May 08, 2026 8:10 pm
Looking to replace the original mounts on my E type series 3 experimental model -EX102. Usual series 3 mounts are not direct replacement neither are series 2. The single shaft on the rear is short (about 1”) and the 3 holes are inline. I understand they were fitted to series 1. Does anyone have new olds stock or no supplier as I would like to keep as original as possible.
Many thanks
#2 Re: Metalastik 17/903 4 steering rack mount
Post by Gfhug » Sat May 09, 2026 7:10 am
Simon, can’t help you there, but please do tell us more about your car. It sounds interesting.
#3 Re: Metalastik 17/903 4 steering rack mount
Post by mgcjag » Sat May 09, 2026 7:30 am
Hi Simon....I think these mounts were used on the very early S1 racks?......interesting ....there must be a solution as lots of early cars have been restored....if you cant find replacements then...could you modify S2/3 mounts to fit....or consider making solid mounts.....Steve...ps have flagged this to someone who may know...
Simon2824
#4 Re: Metalastik 17/903 4 steering rack mount
Post by Simon2824 » Sat May 09, 2026 2:12 pm
The series 2 is similar in look but the size is different and has a longer thread. The 3 is correct dimensions but curved ends. Seems I’ll have to go for these unless I order 1200 from the manufacturer….
