Metalastik 17/903 4 steering rack mount
Simon2824
#1 Metalastik 17/903 4 steering rack mount
Post by Simon2824 » Fri May 08, 2026 8:10 pm
Looking to replace the original mounts on my E type series 3 experimental model -EX102. Usual series 3 mounts are not direct replacement neither are series 2. The single shaft on the rear is short (about 1”) and the 3 holes are inline. I understand they were fitted to series 1. Does anyone have new olds stock or no supplier as I would like to keep as original as possible.
Many thanks
#2 Re: Metalastik 17/903 4 steering rack mount
Post by Gfhug » Sat May 09, 2026 7:10 am
Simon, can’t help you there, but please do tell us more about your car. It sounds interesting.
#3 Re: Metalastik 17/903 4 steering rack mount
Post by mgcjag » Sat May 09, 2026 7:30 am
Hi Simon....I think these mounts were used on the very early S1 racks?......interesting ....there must be a solution as lots of early cars have been restored....if you cant find replacements then...could you modify S2/3 mounts to fit....or consider making solid mounts.....Steve...ps have flagged this to someone who may know...
Simon2824
#4 Re: Metalastik 17/903 4 steering rack mount
Post by Simon2824 » Sat May 09, 2026 2:12 pm
The series 2 is similar in look but the size is different and has a longer thread. The 3 is correct dimensions but curved ends. Seems I’ll have to go for these unless I order 1200 from the manufacturer….
Simon2824
#5 Re: Metalastik 17/903 4 steering rack mount
Post by Simon2824 » Sat May 09, 2026 2:22 pm
If you AI Jaguar experimental EX102 you will get quite detailed info. It is one of 4 produced, the only LHD, has series 3 suspension, cooling , brakes and bonnet. The scope on the front is smaller than the manufactured series 3. A lot of the metal work on the bulkhead is hand welded. Brake ducts similar. USA rear prop ratio. Did have emissions fitted. All paper work from 1976.
#6 Re: Metalastik 17/903 4 steering rack mount
Post by mgcjag » Sat May 09, 2026 2:30 pm
The guy I flagged it to is investigating....hold fire for a while....Steve
Simon2824
#7 Re: Metalastik 17/903 4 steering rack mount
Post by Simon2824 » Sun May 10, 2026 11:12 am
Thank you I await in hope
1954Etype
#8 Re: Metalastik 17/903 4 steering rack mount
Post by 1954Etype » Mon May 11, 2026 2:10 pm
I have checked 2 early cars (47 and 39) and they both have the 'normal' s1 mounts with the long studs. I see in the parts book the mount was changed early on in production but both of these cars were fitted with the first type so it looks like what you have is a hybrid mount of some type.
Might be best if you looked at other models?
Sorry I can't be of any more help.
Angus 67 FHC 1E33656
61 OTS 875047
#9 Re: Metalastik 17/903 4 steering rack mount
Post by mgcjag » Mon May 11, 2026 2:15 pm
Hi Simon.....Angus is the expert I flagged it to.....so no joy there......thanks Angus.........
Simon2824
#10 Re: Metalastik 17/903 4 steering rack mount
Post by Simon2824 » Mon May 11, 2026 7:56 pm
Thank you mgcjag and to Angus for your time on my behalf. I have been doing research and so far cannot find anyone who recognises it all I have found is a mention of the shorter stud on the series 1 to not catch! But not saying what.
