Draper cross beam trolley jack
DBSV8
#1 Draper cross beam trolley jack
Post by DBSV8 » Tue May 08, 2012 3:17 am
Seems to be a usefull addition for jacking up your pride and joy , anyone used one of these
Foot hard down, eyes shut , smile
Post by Heuer » Tue May 08, 2012 2:49 pm
Not sure you would get the jack and cross beam under an E-Type.
MLBS3V12
Post by MLBS3V12 » Tue May 08, 2012 4:49 pm
I've use twice a palett truck, and this seems to me an interesting alternate solution.
I've olso used it to remove a second IRS edgeways.
Michel
Le chemin sera long!...
wol916
Post by wol916 » Tue May 08, 2012 6:46 pm
I use one of these,
http://www.machinemart.co.uk/shop/produ ... -020113050
which will work with the beam attachment.
Warren
S1 FHC 4.2 OSB
DBSV8
Post by DBSV8 » Wed May 09, 2012 9:13 am
wol916 wrote:I use one of these,
that looks good
what type of jack do you normally casrry in case of punctures and where is the prefered jacking point front and back
thanks
wol916
Post by wol916 » Wed May 09, 2012 6:18 pm
Still under restoration so I will have to wait and see re punctures but I suspect the standard jack will suffice. As for jacking in the work shop with all cars I prefer to jack under a suspension mount where possible as these are designed to carry the weight of the car. Uryk at etype fabs provided me with a rather nice piece of hard wood cut to fit the front frame, not used it yet as it seems a shame to get it dirty.
Warren
S1 FHC 4.2 OSB
